Home » Eclipse Projects » BIRT » Bar Chart - Handling big variance of values(Set minimum bar height)
Bar Chart - Handling big variance of values [message #903360] Thu, 23 August 2012 06:41 Go to next message
Ricardo Rodrigues is currently offline Ricardo Rodrigues
For big variances of values (see example attached) using a bar chart, the bars with lower value are for some chart sizes not displayed or almost not visible.
Is there any solution for this, like set minimum bar height or introduce a squiggly line in the middle of the Y axis so that the majority of the values can be looked properly, regarding the example attached we could have <500 items completed and >9000 items completed
[Updated on: Thu, 23 August 2012 06:42]
Report message to a moderator
Re: Bar Chart - Handling big variance of values [message #903438 is a reply to message #903360] Thu, 23 August 2012 11:53 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Ricardo
Currently we do not have a tear style chart, but have you looked at
using a logarithmic scale? Select the y-axis on the third tab of the
chart wizard and change the type from linear to logarithmic.
Jason
> Thanks
Jason Weathersby
BIRT Exchange
Re: Bar Chart - Handling big variance of values [message #903628 is a reply to message #903438] Fri, 24 August 2012 11:12 Go to previous message
That works perfectly thank you
Previous Topic:convert datetime to date report parameter
Next Topic:Access Data Row in Master Page Header/Footer
Current Time: Tue May 21 12:57:12 EDT 2013
Powered by FUDForum. Page generated in 0.01648 seconds
