However, when I try start the server, I always get the follow exception:
!MESSAGE Unknown DB adapter: mysql
!STACK 0
java.lang.IllegalArgumentException: Unknown DB adapter: mysql
at org.eclipse.emf.cdo.server.internal.db.DBStoreFactory.getDBAdapter(DBStoreFactory.java:105)
at org.eclipse.emf.cdo.server.internal.db.DBStoreFactory.createStore(DBStoreFactory.java:52)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.createStore(RepositoryConfigurator.java:292)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getRepository(RepositoryConfigurator.java:164)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:106)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:679)
I have tried using a h2 database, and there is not problem.
Am 23.08.2012 11:44, schrieb José Miguel P.:
> Hello!
> First to all, thanks for your help ;)
> I'm trying use CDO with a MySQL database. In my cdo-server.xml I have uncommented the lines for it, and my
> cdo-server.xml looks like:
> <cdoServer>
> <!--acceptor type="http"/ -->
> <acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
> <!-- negotiator type="challenge" description="/temp/users.db"/ -->
> </acceptor>
> <repository name="repo1">
> <property name="overrideUUID" value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
Just a note: This property is used with value="" (the empty string) to bypass the automatic UUID generation and use the
repository's name as a UUID instead.
> <property name="supportingAudits" value="true"/>
> <store type="db">
> <mappingStrategy type="horizontal">
> <property name="qualifiedNames" value="false"/>
> <property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
> <property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
The preceeding two properties are no longer recognized.
> </mappingStrategy>
> <dbAdapter name="mysql"/>
> <dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
> url="jdbc:mysql://localhost/cdoTest"
> user="root"/>
> </store>
> </repository>
> </cdoServer>
That's usually an indication that one of the following statements is true:
1) You're running in OSGi and forgot to deploy the org.eclipse.net4j.db.mysql bundle, *or*
2) Your're running standalone and forgot to IDBAdapter.REGISTRY.put(MYSQLAdapter.NAME, new MYSQLAdapter());
> !STACK 0
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> Anyone know what is happening with mysql?
> Thanks for your help!
