Home » Eclipse Projects » EGL Development Tools » gridlayout background(Can gridlayout display a background image)
gridlayout background [message #901115] Thu, 09 August 2012 17:00 Go to next message
Nathan Reed is currently offline Nathan Reed
Member
Mac OSX 10.6.8
Eclipse Inidgo 3.7 2 bit
EGL 0.8.1
I am trying to display a background image in a widget on a gridlayout using a css class (code below). I do not see the image in design or preview.
My css file is in webcontent>css.
My image is in webcontent>css>icons.
I am using this path without issue in other code.
Is what I am trying to do possible (background image on gridlayout)? Or do I have a coding problem? Can anyone help with this?
package client;
import org.eclipse.edt.rui.widgets.GridLayout;
handler WelcomeBox type RUIWidget{targetWidget = welcomeGrid, onConstructionFunction = start, cssFile = "css/CuttingInstructions.css", @VEWidget{category = "Custom"}}
    welcomeGrid gridlayout{ rows = 5, columns = 1,
		height = 385,
		width = 655,
		class = "dialogpanelc",
		children = [  ]};
    function start()
    end
end
.dialogpanelc {
background-image: url("icons/dialogpanelc.jpg");
background-repeat: no-repeat;
Re: gridlayout background [message #903193 is a reply to message #901115] Wed, 22 August 2012 09:13 Go to previous messageGo to next message
James Caron is currently offline James Caron
I had a similar problem and my solution, although I'm not sure it applies, was to place the gridlayout in a Div and apply the css class to the div. You may also want to try applying the css directly to the widget in a style tag for testing to reduce the number of variables.
Re: gridlayout background [message #903197 is a reply to message #903193] Wed, 22 August 2012 09:25 Go to previous messageGo to next message
Member
James:
Thanks for the input.
I gave up on trying to place the background on the gridlayout. Thought I was doing that in RBD but now I do not remember.
I had already changed all my code to doing similar to what you suggest. My example used class but I was actually using style tag in my production.
Makes me wary of using any css at all regarding gridlayout.
Appreciate you responding,
Nathan Reed
Re: gridlayout background [message #903212 is a reply to message #901115] Wed, 22 August 2012 10:04 Go to previous message
Member
FYI:
This does work.
updateGrid GridLayout{ columns = 1, rows = 4, cellPadding = 4, children = [  ],
	width = 300,
	height = 300,
	background = "url(css/icons/loadingimage300x300.gif)" };
Thx,
Nathan Reed
[Updated on: Wed, 22 August 2012 10:05]
Report message to a moderator
Previous Topic:Contributing to the EDT project
Next Topic:Library List management call RPG Programs
Current Time: Wed May 22 10:34:06 EDT 2013
Powered by FUDForum. Page generated in 0.02283 seconds
