Home » Modeling » EMF » [CDO] CDO thread prevent JVM to exit on client side standalone
[CDO] CDO thread prevent JVM to exit on client side standalone [message #903150] Wed, 22 August 2012 05:01 Go to next message
Yvan Lussaud is currently offline Yvan Lussaud
I'm using using the client side of CDO in standalone mode (pure Java). When I run the followinf code with a CDO server running evreything is fine. But when the server is not running I get a ConnectorException about a timeout, then the following thread prevent the JVM from exiting. How can I avoid this ?
Thread [ReceiveSerializer-Channel[Control, CLIENT]] (Suspended)
Unsafe.park(boolean, long) line: not available [native method]
LockSupport.parkNanos(Object, long) line: 226
AbstractQueuedSynchronizer$ConditionObject.awaitNanos(long) line: 2081
LinkedBlockingQueue<E>.poll(long, TimeUnit) line: 423
Channel$1ChannelReceiveSerializer(QueueWorker<E>).doWork(Worker$WorkContext) line: 78
Channel$1ChannelReceiveSerializer(QueueWorker<E>).work(Worker$WorkContext) line: 72
Worker$WorkerThread.run() line: 206
----------------- code -----------------
* @param args
IManagedContainer container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container);
CDONet4jUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
container.activate();
IConnector connector = null;
try {
connector = Net4jUtil.getConnector(container, "tcp://localhost:2036/");
} catch (ConnectorException e) {
LifecycleUtil.deactivate(container);
// I also tried : container.deactivate();
System.out.println(e.getMessage());
I'm using :
org.eclipse.emf.cdo 4.0.1
org.eclipse.emf.cdo.net4j 4.0.1
org.eclipse.net4j 4.0.0
regards,
Yvan.
Re: [CDO] CDO thread prevent JVM to exit on client side standalone [message #903154 is a reply to message #903150] Wed, 22 August 2012 05:11 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Hi Yvan,
CDO 4.0 is out of maintenance. Can you please test that the problem persists in 4.1 and, if so, submit a bugzilla with
the infos you've given here?
Cheers
/Eike
http://www.esc-net.de
Am 22.08.2012 11:01, schrieb Yvan Lussaud:
> * @param args
> public static void main(String[] args) {
> try {
> I'm using :
> regards,
> Yvan.
Re: [CDO] CDO thread prevent JVM to exit on client side standalone [message #903175 is a reply to message #903154] Wed, 22 August 2012 08:01 Go to previous message
I have the same behavior with CDO 4.1.0. I opened the following bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=387774
Yvan.
Previous Topic:[CDO] Performance Evaluation
Next Topic:CDO/Teneo Unable to instantiate tuplizer - name collision
Current Time: Thu May 23 08:10:09 EDT 2013
Powered by FUDForum. Page generated in 0.01635 seconds
