| Re: Acceleo and Xtext [message #902540] |
Sat, 18 August 2012 05:49  |
Ed Willink Messages: 3183 Registered: July 2009 |
You have been asking this question for some time on the M2T mailing
list, which is where it belongs.
However you just provide us parts of your program without any indication
how you invoke them.
The more partial information you provide the less attractive it is to
try to help you.
As Christian demonstrated, the basic functionality work fine, so
somewhere you are doing something odd, and you have not told us about it.
If you want help, you need to help yourself, by helping us. Provide a
simple zipped project and launch configuration that demonstrates the
problem. Do not provide snippets that require us to spend time
mis-re-developing what you have failed to provide.
Ed Willink
On 18/08/2012 09:44, Andrea Sindico wrote:
> I am in the middle of an ACCELEO Transformation aimed at producing
> code (i.e. Java) from an input UML model.
> Some elements of this UML model (i.e. Activities Opaque actions)
> contain some text which is conform to an Xtext grammar and I'd like to
> get the equivalent AST Ecore representation in the ACCELEO
> transformation.
> To this end I have developed a Java class with a method which takes as
> input a string, containing the DSL excerpt, and produces an ECORE
> model conform to it (see
> http://www.eclipse.org/forums/index.php/m/901947/#msg_901947 for
> further details). I have tested it in a separate Java application and
> it seems it works properly.
> I have therefore written a simple ACCELEO module (i.e. getDSLModel)
> wrapping that java class and enabling me to get the Ecore model from
> the DSL textual representation.
> Suppose my DSL (and the equivalent ECORE) consist of a root element
> named DSLModel containing a (0..*) number of DSLStatements (this is a
> simplification). When in ACCELEO I invoke the wrapper from a string,
> containing a correct dsl script, i have noticed it correctly returns a
> ModelImpl
> ['statement1;statement2'.getDSLModel()/]
> so the Java service and the XText parse is working.
> However if I try to get the model statements, i.e.:
> ['statement1;statement2'.getDSLModel().statements/]
> it returns an **"invalid"** string. So I can't use it in a for loop
> I have therefore tried to call the eAllContents() ocl service from the
> model instance i.e.:
> ['statement1;statement2'.getDSLModel().eAllContents()/]
> and it actually returns the list of statements. I do not understand
> why the features of the Ecore entities returned from the Xtext parser
> are not working properly.
> Any help would be very appreciated! Thank you
> here is the Java service which turns a string into a instance of my
> DSL model (ECORE AST). I have tested it with an independent Java
> application and it works fine!
> public class GetDSLModel {
> public DSLModel getDSLModel(String expression){
> DSLStandaloneSetupGenerated dslsas = new
> DSLStandaloneSetupGenerated();
> Injector injector = dslsas.createInjectorAndDoEMFRegistration();
> XtextResourceSet resourceSet =
> injector.getInstance(XtextResourceSet.class);
> resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL,
> Boolean.TRUE);
> Resource resource =
> resourceSet.createResource(URI.createURI("dummy:/example.dsl"));
> InputStream in = new ByteArrayInputStream(expression.getBytes());
> try {
> resource.load(in, resourceSet.getLoadOptions());
> DSLModel model = (DSLModel) resource.getContents().get(0);
> return model;
> } catch (IOException e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> return null;
> Now I need the AST in the main ACCELEO (UML2Text) transformation thus
> here is the Acceleo wrapper
> [query public getDSLModel(str:String): DSLModel =
> (invoke('sfg.baleno.src.mloaders.GetDSLModel','getDSLModel(java.lang.String)',Sequence{str})).oclAsType(DSLModel)/]
> here is what I get if run it
> input: ['statement1;statement2'.getDSLModel()/]
> output: mailto:mypackage.dsl.impl.DSLModelImpl@a1c7a
> input: ['statement1;statement2'.getDSLModel().statements/]
> (Syntactically VALID)
> output: invalid
> input: ['statement1;statement2'.getDSLModel().eAllContents()/]
> output: mailto:mypackage.dsl.impl.DSLStatement@e53202 (......
> Some hours later
> In the Java Class of the main ACCELEO module I have added the
> following lines
> @Override
> public void initialize(EObject element, File folder,
> java.util.List<? extends Object> arguments) throws IOException {
> preInitialize();
> super.initialize(element, folder, arguments);
> @Override
> public void initialize(URI modelURI, File folder, java.util.List<?>
> preInitialize();
> super.initialize(modelURI, folder, arguments);
> protected void preInitialize() {
> DSLStandaloneSetup.doSetup();
> and
> @Override
> public void registerPackages(ResourceSet resourceSet) {
> super.registerPackages(resourceSet);
> if (!isInWorkspace(org.eclipse.uml2.uml.UMLPackage.class)) {
> resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UMLPackage.eINSTANCE.getNsURI(),
> org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
> if (!isInWorkspace(mypackages.DSLPackage.class)) {
> resourceSet.getPackageRegistry().put(mypackages.DSLPackage.eINSTANCE.getNsURI(),
> mypackages.DSLPackage.eINSTANCE);
> EcoreUtil.resolveAll(resourceSet);
> but it still behaves the same.
> Is there anyone who managed to use Xtext with Acceleo this way?
| Re: Acceleo and Xtext [message #902910 is a reply to message #902540] |
Tue, 21 August 2012 02:28   |
Andrea Sindico Messages: 252 Registered: November 2010 |
Hi Ed as it concerns both Acceleo and Xtext I thought it was a good idea to post it in both the forums. At this link https://docs.google.com/open?id=0B2_ovo8IiZaZaXdNdFdPMTI4Yjg you find a zipped workspace containing both the Acceleo and the Xtext project plus a launchMe.launch configuration you can use to run the ACceleo transformation.
If you run it as an acceleo application (The launchMe.launch) you get this output:
UML
test1: Class1
DSL
test1: org.xtext.example.mydsl.myDsl.impl.ModelImpl@1ae6ee8
test2: invalid
while if you run it as a Java application you get the right output:
UML
test1: Class1
DSL
test1: org.xtext.example.mydsl.myDsl.impl.ModelImpl@598fffdd
test2: org.xtext.example.mydsl.myDsl.impl.GreetingImpl@2f0dd706 (name: tester)
tester
Thank you for your help.
Follow me on Twitter @andreasindico
[Updated on: Tue, 21 August 2012 02:29] Report message to a moderator
| Re: Acceleo and Xtext [message #903167 is a reply to message #903132] |
Wed, 22 August 2012 07:12  |
My requirements are particularly challenging. I am using Acceleo as a
code generator for development OCL meta-models while Acceleo is using
production OCL meta-models as part of its functionality. I therefore
stress the namespace resolution very hard, and find the odd problem or two.
So yes, I have seen many strange things happening with PrimitiveTypes
(just look at the Acceleo Bugzillas I have raised.)
Ed Willink
On 22/08/2012 08:42, Andrea Sindico wrote:
> Hi Ed, I also noticed that when executed as a Java Application it
> behaves differently for what concerns PrimitiveTypes (see
> http://www.eclipse.org/forums/index.php/t/369811/). Have you ever
> experienced something like that? am I missing something in the related
> launch configuration? (... continue on the related post)
FUDForum. Page generated in 0.04716 seconds
