| Webservice date conversion problem [message #902946] |
Tue, 21 August 2012 07:28  |
Bertin Kiekebosch Messages: 223 Registered: August 2011 |
I am converting an Java Swing application to a Scout application. I created a Webservice Consumer. When I call this webservice I get the following order:
javax.xml.ws.soap.SOAPFaultException: Server was unable to read request. ---> There is an error in XML document (1, 311). ---> String was not recognized as a valid DateTime.]]
I can still call the webService with my old Java application from the same computer. So I assume that the Scout webservice implementation or JAX have an other way to convert dates that do not match with the server side.
How can I configure or fix this?
Regards Bertin
FUDForum. Page generated in 0.02642 seconds
