Home » Modeling » ATL » Determine if an unsettable attribute 'isSet'
Determine if an unsettable attribute 'isSet' [message #902958] Tue, 21 August 2012 08:12
Gunnar Arndt is currently offline Gunnar Arndt
Member
In a class of an Ecore model I'm using, there is an unsettable boolean attribute literalValue, i.e. there is an additional boolean attribute literalValueESet in the implementation, and interface methods isSetLiteralValue() and unsetLiteralValue().
Now, I'm trying to find a way in ATL to query if literalValue is set or unset. Do you have any idea how to do that?
Even
source->refInvokeOperation('isSetLiteralValue', Sequence{})
fails with the message
Operation isSetLiteralValue not found on (the concerned EObject)
, but probably, there is an immediate 'ATL' way to query that attribute?
Thanks for your help.
Previous Topic:Comparing Large Numbers Fails with ATL 3.2.1
Next Topic:EBoolean
Current Time: Wed May 22 19:39:29 EDT 2013
Powered by FUDForum. Page generated in 0.05550 seconds
