Home » Modeling » Papyrus » Generate UML Diagram from ecore/ecorediag
Generate UML Diagram from ecore/ecorediag [message #898709] Fri, 27 July 2012 05:42 Go to next message
John M. is currently offline John M.
I am using the daily build version of Papyrus. Is there any possibility to generate an UML diagramm from ecore/ecorediag file?
Re: Generate UML Diagram from ecore/ecorediag [message #902759 is a reply to message #898709] Mon, 20 August 2012 06:00 Go to previous messageGo to next message
Alexandra Bardiau is currently offline Alexandra Bardiau
You can have a look at this old tutorial on creating Papyrus diagrams:
dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/examples/others/org.eclipse.papyrus.example.diagram.simplediagram/docs/PapyrusDevelopperTutorial_OnDiagramCreating.odt
I'm trying to use this as well, however I'm getting an error on the last step, so I haven't quite figured out how to complete the tutorial... But I think it's a good place to start.
There are a couple more places where you could find some useful information, however the docs are usually incomplete and/or outdated...
wiki.eclipse.org/Papyrus_User_Guide
dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/doc/DevelopperDocuments/cookbook/PapyrusCookBook.odt
If you figure out how to solve your problem, please post a solution (or an idea), I'd appreciate the help.
Good luck!
Alexandra Bardiau
[Updated on: Mon, 20 August 2012 06:28]
Report message to a moderator
Re: Generate UML Diagram from ecore/ecorediag [message #902775 is a reply to message #902759] Mon, 20 August 2012 07:54 Go to previous messageGo to next message
If you'll be using the tutorial, you'd want to check out this forum post as well, it seems to solve the issue I had on the last step:
www.eclipse.org/forums/index.php/m/902774/#msg_902774
Alexandra Bardiau
[Updated on: Mon, 20 August 2012 07:54]
Re: Generate UML Diagram from ecore/ecorediag [message #902809 is a reply to message #902775] Mon, 20 August 2012 10:51 Go to previous message
Thanks for the links, but it seems that there is a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317156
Previous Topic:Stereotype generalisation producing exceptions
Next Topic:Patterns to catch Papyrus UI contributions
Current Time: Wed May 22 15:41:30 EDT 2013
Powered by FUDForum. Page generated in 0.06657 seconds
