| Converter [message #890221] |
Thu, 21 June 2012 09:52  |
Peter Nagy Messages: 4 Registered: September 2011 |
Junior Member |
Hi!
I am trying to use the GUI's "Edit Data Binding" window to attach a Converter to one of my data bindings. After selecting the Converter(ExchangeMailToStringConverter) I get the following error message:
"Model converter Class does not contains public constructor(s):"
ExchangeMailToStringConverter().
The source of the Converter class:
import java.util.List;
import org.eclipse.core.databinding.conversion.Converter;
import com.moyosoft.exchange.mail.ExchangeMail;
public class ExchangeMailToStringConverter extends Converter{
public ExchangeMailToStringConverter(Object fromType, Object toType) {
super(fromType, toType);
public Object convert(Object fromObject) {
List<ExchangeMail> mails = (List<ExchangeMail>)fromObject;
return mails.get(Main.getInstance().getN());
Modifying the GUI's source manually works fine:
UpdateValueStrategy uvs = new UpdateValueStrategy();
uvs.setConverter(new ExchangeMailToStringConverter(ExchangeMail.class,String.class));
bindingContext.bindValue(text_4ObserveTextObserveWidget, logicKurtIpListObserveValue, null, uvs);
Any suggestions?
Thanks!
NagPer
| Re: Converter [message #902736 is a reply to message #890257] |
Mon, 20 August 2012 04:14  |
Junior Member |
Eric Clayberg wrote on Thu, 21 June 2012 11:58That error message seems very specific...it is looking for a default constructor. Presumably, your custom converter class should know what it wants to convert from/to. Have you tried something like this?
public ExchangeMailToStringConverter() {
super(ExchangeMail.class,String.class);
That works Eric! Thank you!
FUDForum. Page generated in 0.01658 seconds
