Home » Newcomers » Newcomers » Difference between Eclipse Juno,Indigo,Helios and Galileo(Setup to install for Android Developer)
Difference between Eclipse Juno,Indigo,Helios and Galileo [message #902542] Sat, 18 August 2012 05:59 Go to next message
Bhargava Krishna is currently offline Bhargava Krishna
Sir,
Am a student, learner of Android, As I tried to install plugin with 'Net Beans' found uneasy to use, I was suggested to install and work on Eclipse, can you please suggest which setup has to be installed.
Please give me some explanation regarding the difference between Eclipse Juno, Indigo,Helios and Galileo.
Krishna
Re: Difference between Eclipse Juno,Indigo,Helios and Galileo [message #902690 is a reply to message #902542] Sun, 19 August 2012 12:35 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
http://wiki.eclipse.org/Simultaneous_Release
Juno is the newest, and should be the one you start with.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Resizing views/windows/shell/display
Next Topic:Network Settings Juno (Build id: 20120614-1722)
Current Time: Tue May 21 22:41:50 EDT 2013
Powered by FUDForum. Page generated in 0.03340 seconds
