Home » Eclipse Projects » WindowBuilder » How use wbp-palette-commands.xml inside plug-in project
How use wbp-palette-commands.xml inside plug-in project [message #902634] Thu, 16 August 2012 15:31
Arthur Fücher is currently offline Arthur Fücher
Member
I want to restrict the components and categories in the toolkit. I want to know if can I use the wbp-palette-commands.xml inside my plugin.
I see that if I put this XML in a folder called wbp-meta inside the project where my plug-in is running it works. But I want that the plug-in do this restriction...
Are there anyway to do that? Put this XML inside the plug-in? Or exists a extension point to do that?
[]'s
Previous Topic:Re: How add restriction to delete a component
Next Topic:Re: How use wbp-palette-commands.xml inside plug-in project
Current Time: Thu May 23 19:45:58 EDT 2013
Powered by FUDForum. Page generated in 0.01443 seconds
