Home » Modeling » TMF (Xtext) » Formatter indentation Increment/Decrement
Formatter indentation Increment/Decrement [message #902528] Sat, 18 August 2012 03:53
Charalampos Alexopoulos is currently offline Charalampos Alexopoulos
I want to have a code formatted like this:
rotate([90,0,0])
   translate([20,0,0])
       cube(size=30);
cube(size=50);
I have a 'Modeling' rule which include 'rotate' and translate' and ends with ')' or optional curled brackets, and i have a few rules wich ends with semicolon.The grammar becomes very complicated to present a simplified version.
I use a command like:
c.setIndentationIncrement().after(f.getModelingRule());
This line does the increments correctly, what i can't do is the decrements after semicolon. Is that possible?
Thank you
Previous Topic:Sharing experience of writing grammar in Xtext
Next Topic:How can I setup xtend-maven-plugin encode for Xtend2 generation?
Current Time: Wed May 22 09:17:03 EDT 2013
Powered by FUDForum. Page generated in 0.06428 seconds
