| Unable to Run [message #902508] |
Fri, 17 August 2012 21:57  |
Jeremy Lennert Messages: 3 Registered: August 2012 |
Junior Member |
I've just downloaded Zend Eclipse PDT from Zend (following a link from the top of this page), unzipped, created a PHP project with a Hello, World script, and tried to run.
After confirming the URL to access, Eclipse reported the following error:
An internal error occurred during: "Launching newfile".
org/zend/php/zendserver/deployment/core/debugger/IDeploymentHelper
I get the same error again each time I try to run.
Also, upon going to "Run Configurations", the options screen for the auto-created configuration doesn't display; it initially shows as blank, and if I select another item and then return to it, the previous item's options are still displayed. Simultaneously, behind the "Run Configurations" window, another error window pops up saying:
Error creation extension for extension-point org.eclipse.php.server.ui.serverTabs
Plug-in "org.zend.php.zendserver.deployment.debug.ui" was unable to instantiate class "org.zend.php.zendserver.deployment.debug.ui.config.DeploymentLaunchConfigurationTab".
I've made sure my Java installation is up to date. A coworker has tried downloading Eclipse from the same source and does not appear to have this problem.
Incidentally, if I try to view the php file with a separate web browser pointed at localhost, it comes up fine and works as expected.
Any ideas what could be wrong or how to fix this?
| Re: Unable to Run [message #903090 is a reply to message #903059] |
Tue, 21 August 2012 18:22  |
Junior Member |
Behavior appears unchanged after removing .metadata\.plugins\org.eclipse.dltk.core.index.sql.h2
Unzipping in a new location produces the same behavior.
Starting a new workspace in a new location produces the same behavior.
However, I've discovered that starting with Eclipse Classic 4.2 (from here) and then separately installing PDT (following the directions here) seems to work fine. So I guess I'll proceed with that until something else goes wrong...
FUDForum. Page generated in 0.01585 seconds
