Home » Language IDEs » Java Development Tools (JDT) » How can I use eclipse default package explorer to create my own package explorer(I want to create my own package explorer which will show files on the base of some condition)
How can I use eclipse default package explorer to create my own package explorer [message #901932] Wed, 15 August 2012 02:55 Go to next message
Muhammad Tahir is currently offline Muhammad Tahir
Hello All,
I want to show only the files in the package explorer which has GUI. How can I use exsisting package explorer so that I can do this by making less changes. Is there any way to extend all functionality of default package explorer and just override specific part which i want to change?
I would be greatfull for your help
M-Tahir
[Updated on: Wed, 15 August 2012 03:44]
Report message to a moderator
Re: How can I use eclipse default package explorer to create my own package explorer [message #901934 is a reply to message #901932] Wed, 15 August 2012 03:22 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 15.08.2012 08:55, Muhammad Tahir wrote:
> Hello All,
> making less changes
Why not use the 'Navigator' view then?
Dani
Re: How can I use eclipse default package explorer to create my own package explorer [message #902165 is a reply to message #901934] Thu, 16 August 2012 04:13 Go to previous messageGo to next message
I can't use Navigator view. Because I need to show only files that contains GUI components. Before this I need to parse the file first and check is that file has GUI components or not. So I need to filter the contents on runtime.
Re: How can I use eclipse default package explorer to create my own package explorer [message #902185 is a reply to message #902165] Thu, 16 August 2012 05:22 Go to previous messageGo to next message
I see. In that case you either want to use the Common Navigator
framework to build your own view or you provide extensions to the
existing 'Project Explorer' view (take a look at the
org.eclipse.ui.navigator.* extension points).
Dani
Re: How can I use eclipse default package explorer to create my own package explorer [message #902318 is a reply to message #902185] Thu, 16 August 2012 23:29 Go to previous messageGo to next message
Thanks for your reply. I am just wondering that is this would be more better for me to change org.eclipse.jdt.ui plugin directly?
Re: How can I use eclipse default package explorer to create my own package explorer [message #902329 is a reply to message #902318] Fri, 17 August 2012 02:11 Go to previous message
It is, because the Package Explorer is not meant to be extended and is
internal.
Dani
Previous Topic:Juno - Spurious warning: Resource Leak
Next Topic:activePerspective in workbench.xml not starting
Current Time: Sat May 18 20:08:56 EDT 2013
Powered by FUDForum. Page generated in 0.04416 seconds
