Home » Eclipse Projects » Virgo » Timeout when starting Blueprint Bundle in Virgo 3.5.0.RELEASE(I created a working OSGi Bundle without a "/OSGI-INF/blueprint/blueprint.xml" and it starts, add the XML and it fails to start.)
Timeout when starting Blueprint Bundle in Virgo 3.5.0.RELEASE [message #902315] Thu, 16 August 2012 22:47 Go to next message
William Curtis is currently offline William Curtis
I created a new bundle project using maven-bundle-plugin. This plugin wraps log4j-1.2.17 and exposes the internal workings of log4j to other bundles that use too much of log4j that I can't control. (It actually "inlines" the log4j classes)
This works well.
I defined a service interface and implementation in the bundle as well that could be used to control the log appenders and levels for loggers. (The final goal was to add a console interface to allow OSGi console level manipulation of log4j)
I went to define that service interface in the "/OSGI-INF/blueprint/blueprint.xml" and the whole bundle fails to start. It times out and never starts and the bundle "un-resolves" and uninstalls.
I took the definitions of the service and interface out of the .xml and re-deployed. So now, the XML just has the "blueprint" begin and end tags and it still will not start. It just hangs.
<blueprint xmlns="htp://www.osgi.org/xmlns/blueprint/v1.0.0">
</blueprint>
I don't know where to start debugging this. I can try to start the bundle from the osgi console, but still no help.
Thanks for any help in advance...
Re: Timeout when starting Blueprint Bundle in Virgo 3.5.0.RELEASE [message #916862 is a reply to message #902315] Wed, 19 September 2012 11:06 Go to previous message
Glyn Normington is currently offline Glyn Normington
That's strange. Please could you create a minimal testcase to reproduce and raise a bug?
Previous Topic:Virgo in the cloud (AWS) - provisioning suggestions?
Next Topic:@Administrator/Moderator: Cleanup
Current Time: Sun May 19 01:13:16 EDT 2013
Powered by FUDForum. Page generated in 0.06377 seconds
