Home » Language IDEs » AJDT » Softening exception in try-with-resources
Softening exception in try-with-resources [message #901908] Tue, 14 August 2012 21:06 Go to next message
Emanuel Rabina is currently offline Emanuel Rabina
I've been making use of the new try-with-resources syntax when I upgraded to AJDT 2.2.0 a few weeks back (and could start using Java 7 in my AspectJ projects), but the aspects I wrote to soften IOException don't seem to catch the automatic close() created by the new syntax:
try (BufferedReader reader = new BufferedReader(new FileReader("test.txt"))) {
  System.out.println(reader.readLine());
declare soft: IOException: within(*)
Eclipse reports a compile error on the try... line, saying: "Unhandled exception type IOException thrown by automatic close() invocation on reader". The only way I've managed to get around this is to add a catch clause to the try for the IOException, or to have the method throw IOException, which kind of goes against the reason I did the exception softening in the first place (to cut down on throws or catch clauses).
Is there another way to soften the automatic close while using the new syntax?
Re: Softening exception in try-with-resources [message #901918 is a reply to message #901908] Wed, 15 August 2012 01:04 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew Eisenberg
From your description, I can't tell if this is a problem with AJDT or AspectJ.
Do you see the error appearing in the problems view, or is it only in the editor? Also, do you see any exceptions in your error log?
Re: Softening exception in try-with-resources [message #901919 is a reply to message #901918] Wed, 15 August 2012 01:05 Go to previous messageGo to next message
Also, (and this may be silly and obvious) make sure that your source compliance level is set to 1.7.
Re: Softening exception in try-with-resources [message #901931 is a reply to message #901919] Wed, 15 August 2012 02:53 Go to previous messageGo to next message
The error appears in both the problems view and in the editor ('reader' in the example above is underlined red and the error icon is also showing in the left of the line). No additional exceptions/errors show in the Error Log (only info messages about other things like how long weaving/building the rest of the workspace took). Compliance level is set to 1.7.
I just tried compiling the code with ajc via the command line and I get a compile error with the same message and line number, so if there's a problem it might be with AspectJ.
[Updated on: Wed, 15 August 2012 02:55]
Report message to a moderator
Re: Softening exception in try-with-resources [message #902020 is a reply to message #901931] Wed, 15 August 2012 10:08 Go to previous messageGo to next message
This does sound like an aspectj problem. Since this is a forum for AJDT, you'd get a better response on the aspectj mailing list or by raising a bug on bugzilla.
Mailing list is here:
http://eclipse.org/aspectj/userlists.php
Bugzilla is here:
https://bugs.eclipse.org/bugs/
Re: Softening exception in try-with-resources [message #902314 is a reply to message #902020] Thu, 16 August 2012 20:47 Go to previous message
Thanks Andrew, I've raised a bug on Bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=387444
Previous Topic:Android/Aspectj w/Google Maps ant build fail
Next Topic:Help
Current Time: Tue May 28 05:02:03 EDT 2013
Powered by FUDForum. Page generated in 0.01909 seconds
