Home » Eclipse Projects » Web Tools Project (WTP) » Using the XML Catalog outside WTP
Using the XML Catalog outside WTP [message #902261] Thu, 16 August 2012 11:30
Kevin Milburn is currently offline Kevin Milburn
I'm creating an RCP application which will utilise several components from the WTP, however, I'm having trouble trying to make use of some of it's core features, for which everything useful appears to be internal!
Ideally, I'd like to set the System property xml.catalog.className but have not succeeded in finding anything within WTP that's compatible (i.e. CatalogResolver derived).
Is there any way to use the WTP's XML Catalog with Xerces directly, and if so, what have I missed?
Previous Topic:MultiPageEditor - working with many files, marking MPE as dirty throw exception
Next Topic:Eclipse IDE for Java EE Developers based on Eclipse 3.8
Current Time: Fri May 24 09:02:59 EDT 2013
Powered by FUDForum. Page generated in 0.01614 seconds
