| Re: [Texo] Complete tutorial (from scratch) [message #902304 is a reply to message #902279] |
Thu, 16 August 2012 18:04  |
Martin Taal Messages: 5053 Registered: July 2009 |
The example project is a very simple/straightforward dynamic web project, it is quite easy to create such a web project
in eclipse and then copy the needed jar files from the example project. The example project is a minimal project which
only contains what you need.
If you have experience in doing java web (server) development then afaics it should be manageable to create your own web
project using the example project as a background reference.
As this is open source ;-) : I am quite interested in contributions such as a tutorial you are refering to.
gr. Martin
On 08/16/2012 08:05 PM, JY Mising name wrote:
> Unfortunally, this tuturial not covers creation of example project from zero (not explains with details each steps).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.01592 seconds
