| writing into an editable table cell [message #900939] |
Thu, 09 August 2012 03:27  |
Peter S. Messages: 6 Registered: August 2012 |
Junior Member |
Hi. I'm quite new to Jubula, using v1.2.1 on an RCP-application and having troubles with writing into editable table cells.
I tried everything that came into my mind to put text into the cell, but Jubula always stops the test case due to an "action error", telling me the cell is not editable.
I just managed to write into it by sending single keys, but in this cell there is a time required, thus the syntax gets checked and Jubula makes "02.00" out of my "02:00" (german layout).
EDIT:
I still don't know, why Jubula tells me the cell is not editable, but managed to put "02:00" into the cell in 8 steps: selectCell, pressAnyKey[0], pressAnyKey[2], setToggleKey_CAPSLOCK [true], pressAnyKey[ : ], ... looks inelegant but does the job.
Peter
[Updated on: Fri, 17 August 2012 05:45] Report message to a moderator
| Re: writing into an editable table cell [message #901556 is a reply to message #901493] |
Mon, 13 August 2012 07:41   |
Junior Member |
Hi Alex,
thank you for your reply. Application input text gives me an error with the description "Point to click is outside of component", although the focus IS in the cell (which is obvious, because my static pressAnyKey-attempt works).
Application external input text writes text into my cell, but only if it doesn't contain a special character, e.g. a colon ":" (which is mandatory for my time-column) or whitespace " ". Otherwise an action error says "Invalid Parameter Value".
Is there a way that non-alphanumeric characters are accepted too?
Thanks in advance, Peter
[Updated on: Tue, 14 August 2012 03:36] Report message to a moderator
| Re: writing into an editable table cell [message #902171 is a reply to message #902141] |
Thu, 16 August 2012 04:41  |
Junior Member |
Hi Alex,
this copyTextToClipboard, pressKeyCombination_CTRL_V sequence seems to work perfectly.
Moreover, I actually like it. It is easy to parameterize and takes just two steps more (selectCell, paste) than a replaceText command.
Thank you, Peter
FUDForum. Page generated in 0.02073 seconds
