| C/C++ search does not find everything [message #902144] |
Thu, 16 August 2012 02:33 |
Jan Pohanka Messages: 24 Registered: June 2011 |
Junior Member |
I use Eclipse Indigo for developing Linux kernel. I know it is a quite huge project and indexing is really tricky to set up correctly. Using some howtos find on the web I found that eclipse is quite handy even for this and is able to navigate through kernel code.
Unfortunately C/C++ search is often not able to find symbols that are normally declared/defined. The situation is described well by two attached images. Do someone know where could be the problem and why the definition of the function is not found?
regards
Jan
FUDForum. Page generated in 0.04686 seconds
