Home » Modeling » BPEL Designer » Expression editor doesn't work in Juno
Expression editor doesn't work in Juno [message #902024] Wed, 15 August 2012 10:18
Jean-Marc Terrettaz is currently offline Jean-Marc Terrettaz
Hi all,
I tried the BPEL Designer the last few days - nice tool, congratulations!
I tried it today with Juno (Eclipse 4.2) and noticed that the expression editor doesn't work. For example in an assign expression to variable action, the editor field for the expression does not appear. If I insert the expression directly in the BPEL source, it does not appear in the properties tab.
Same in an if control, it's impossible to edit the condition. The button 'Create a new condition' has no effect.
Shall I fill in a bug?
Previous Topic:[SOLVED] deploy.xml and missing Associated Port
Next Topic:Problem with axis2:Failure
Current Time: Wed May 22 08:49:55 EDT 2013
Powered by FUDForum. Page generated in 0.02347 seconds
