Home » Modeling » TMF (Xtext) » parsing DSL in a Java application
parsing DSL in a Java application [message #901740] Tue, 14 August 2012 08:31 Go to next message
Andrea Sindico is currently offline Andrea Sindico
I need to programmatically turn a text conform to an XText grammar into an AST conform to an ECORE meta-model generated by XText from the same grammar. I know XText also generate the Java classes implementing such parser but I don't know either where they are and how to use it. Any help is very appreciated
I have managed to instantiate the injector
Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
but is still not clear to me how to use it to create an instance of the ParseHelper<MyDSLRootElement> generic class
Re: parsing DSL in a Java application [message #901752 is a reply to message #901740] Tue, 14 August 2012 09:03 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
Short answer: You just load the source file (xxx.mydsl) as an EMF
resource, and then get the model from the EMF resource. Xtext takes care
of the rest.
- henrik
Re: parsing DSL in a Java application [message #901790 is a reply to message #901752] Tue, 14 August 2012 11:19 Go to previous messageGo to next message
Hi Henrik, I guess I haven't understood your answer or my question was not clear enough.
I am in the middle of an ACCELEO Transformation aimed at producing code (i.e. Java) from an input UML model. Some elements of this UML model (i.e. Activities Opaque actions) contain some text which is conform to an Xtext grammar and I'd like to get the equivalent AST Ecore representation in the ACCELEO transformation. To this end I am developing a Java class with a method which takes as input a string, containing the DSL excerpt, and shall produce an ECORE model conform to it. In this way I can write a simple ACCELEO module wrapping that java class and enabling me to get the Ecore model from the DSL textual representation. I hope this clarify why I can't just open a source file.
My question is how can I programmatically ( I mean in a Java Class) turn a string containing a DSL script to the related ECORE model? If it is not that hard may I ask you to post the required lines of code. Thanks a lot in advance
Follow me on Twitter @andreasindico
Re: parsing DSL in a Java application [message #901833 is a reply to message #901790] Tue, 14 August 2012 13:37 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
have a look at http://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
~Christian
Re: parsing DSL in a Java application [message #901947 is a reply to message #901833] Wed, 15 August 2012 05:01 Go to previous message
Thank you Christian, it was indeed what I was looking for
Previous Topic:Synchronized model instance and text editor(s)
Next Topic:Customize code checker
Current Time: Thu May 23 00:35:17 EDT 2013
Powered by FUDForum. Page generated in 0.01801 seconds
