| Using CTRL-TAB to switch between cpp and h files: Always [message #901852] |
Tue, 14 August 2012 14:57  |
Chris Stankevitz Messages: 43 Registered: September 2011 |
Member |
CTRL-TAB switches the editor between .h and .cpp files. This is wonderful, thank you.
Problem:
I sometimes click in things that are not the editor such as the output window (to goto next error). When this happens the focus is no longer in the editor window and CTRL-TAB no longer works.
Question:
How to I get CTRL-TAB to switch between .h and .cpp even after I click in the output window (or any other window/panel/tab/screen/object/color/menu/button/widget/etc)?
Answer:
a) This is impossible
b) Window | preferences | general | keys | Toggle Source/Header | When | "ALWAYS"
c) Window | preferences | general | keys | Toggle Source/Header | When | In Dialogs And Windows
d) Why don't you try writing your own IDE if you think it's so easy you lazy bum
e) [your answer here]
(b) is a trick answer. There is no "ALWAYS" option
(c) did not work either
Thank you,
Chris
FUDForum. Page generated in 0.01563 seconds
