Home » Eclipse Projects » EPF » EPF Composer on Windows 7 Professional 64 bit
EPF Composer on Windows 7 Professional 64 bit [message #828141] Sat, 24 March 2012 05:06 Go to next message
Matthias Racke is currently offline Matthias Racke
Hello there,
are there any plans for an epf composer version compatible with windows 7 professional 64 bit?
kind regards
Matthias
Re: EPF Composer on Windows 7 Professional 64 bit [message #901888 is a reply to message #828141] Tue, 14 August 2012 17:41 Go to previous message
Flavelle Ballem is currently offline Flavelle Ballem
Member
The 32-bit version works very well in Windows 7 Professional 64-bit. The key is what browser / Java JRE you have installed. By default, Windows 7 will use the 32-bit Internet Explorer and when you install the Java JRE it's the 32-bit version. If this is the case in your environment, then the Windows 32-bit EPF will work for you.
Previous Topic:Use Outside of Software Development
Next Topic:Standard page for the published website
Current Time: Sun May 26 04:14:13 EDT 2013
Powered by FUDForum. Page generated in 0.03982 seconds
