NotHandledException with dynamic menu in Juno [message #901877] |
Tue, 14 August 2012 17:14  |
Bastian Krol Messages: 2 Registered: August 2012 |
Junior Member |
I'm the maintainer of the the StartExplorer plug-in. One of its features is broken in Juno. The feature uses the <dynamic> tag to add actions to context menus programatically at runtime. This feature works fine in all Eclipse 3.x versions (up to Indigo) but does not work in the current Juno release (Build id: 20120614-1722).
The commands are added to the menu, but when the user clicks one of them, Eclipse can not find the handler. It silently fails to execute the command and an exception is logged (see below).
The extension point in question in plugin.xml:
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?after=additions">
<menu
label="Dynamic Command Contributions"
id="command.contributions.menu">
<visibleWhen>
<with variable="activeMenuSelection">
<iterate>
<adapt type="org.eclipse.core.resources.IResource" />
</iterate>
</with>
</visibleWhen>
<dynamic
class="command.contributions.ContributedCommandMenuProvider"
id="command.contributions.ContributedCommandMenuProvider">
</dynamic>
</menu>
</menuContribution>
</extension>
ContributedCommandMenuProvider is the class that creates the commands and handlers on the fly, it extends org.eclipse.ui.actions.CompoundContributionItem.
Here is an excerpt:
protected IContributionItem[] getContributionItems() {
this.doCleanup();
return new IContributionItem[] { this.createContributionItem() };
private IContributionItem createContributionItem() {
this.command = this.createCommand();
CommandContributionItemParameter commandContributionItemParameter = new CommandContributionItemParameter( //
this.getServiceLocator(), // IServiceLocator serviceLocator,
this.command.getId(), // String id,
this.command.getId(), // String commandId,
CommandContributionItem.STYLE_PUSH // int style)
commandContributionItemParameter.label = "Contributed Command";
CommandContributionItem contributionItem = new CommandContributionItem(
commandContributionItemParameter);
return contributionItem;
private Command createCommand() {
ICommandService commandService = this
.getCommandService(getServiceLocator());
String commandId = "command.contributions.commandId";
Command command = commandService.getCommand(commandId);
String commandName = "command.contributions.name";
String commandDescription = "Contributed Command";
command.define(commandName, commandDescription,
this.getLazyInitCategory(commandService));
IHandler handler = new CommandContributionHandler();
command.setHandler(handler);
return command;
I also attached the source code of a reduced mini-plug-in to this post that can be used to reproduce the problem. It only adds one command to the menu with the mechanism shown above. The code shown above is also from the reduced example.
When I debug this, I can make the following observations by setting a breakpoint in LegacyHandlerService, line 492 (final Object rc = hs.executeHandler(command, staticContext)): The org.eclipse.core.commands.ParameterizedCommand command has an instance variable of type org.eclipse.core.commands.Command (also named command) which in turn has an private transient IHandler handler. This handler refers to the handler I used when creating the command, so it is clearly there. However, the new Juno code does not use it but uses the method lookUpHandler(IEclipseContext context, String commandId) in HandlerServiceImpl which returns null.
I think this might be a bug in Juno, but before posting a Bugzilla ticket I wanted to ask here if anybody has any clue what goes wrong here. Maybe I just need to adapt my code to the Juno codebase? If so, any pointers in the right direction would be appreciated.
For the plug-in, if you are interested, see http : // basti1302.github.com/startexplorer/
Here is the exception in the log file:
!ENTRY org.eclipse.ui 4 4 2012-08-14 22:19:19.157
!MESSAGE Failed to execute item command.contributions.commandId
!STACK 0
org.eclipse.core.commands.NotHandledException: There is no handler to execute for command command.contributions.commandId
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:494)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:824)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:810)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:800)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.02317 seconds
