Home » Eclipse Projects » DTP » Oracle - Unable to use new syntax connection string when using Database Development Perspective
Oracle - Unable to use new syntax connection string when using Database Development Perspective [message #901821] Tue, 14 August 2012 13:12 Go to next message
Doug Busley is currently offline Doug Busley
Hello Everyone,
I'm having some issues using the database development perspective for our Oracle database. The wizard asks for an SID which is part of the old syntax for connecting. I would like to use the service name instead but the wizard does not allow you to do so and it greys out the input box for the connection url so I can't do it manually.
Essentially, I'd like to do this:
jdbc:oracle:thin:@//HOST:PORT/SERVICE
But it generates this:
jdbc:oracle:thin:@HOST:PORT:SID
Is there a file I can go into and correct the connection url? It won't let me connect with the generated connection url.
Thanks!
Re: Oracle - Unable to use new syntax connection string when using Database Development Perspective [message #901826 is a reply to message #901821] Tue, 14 August 2012 13:24 Go to previous message
Figured it out... used the Other driver instead of the thin driver. That let me put in the connection string to my liking. Smile
Previous Topic:Data Source Explorer shows Informix schemas empty
Next Topic:Moving DataSource definitions from one workspace to another
Current Time: Wed May 29 04:30:05 EDT 2013
Powered by FUDForum. Page generated in 2.12652 seconds
