Home » Newcomers » Newcomers » Read-only files(How to mark them in project explorer and avoid "File X is read-only!" message)
icon5.gif  Read-only files [message #901731] Tue, 14 August 2012 07:43 Go to next message
asdf sdf is currently offline asdf sdf
In my projects I have a lot of read-only files and am facing two problems.
1)
First of all, I would like to mark read-only files in the project explorers view. Either as label decoration, different file icon or font modifications of the file's name, etc.
My search for a read only decoration brought me to this example, however I could not find a standard decorator nor a marketplace plugin
2)
In case I accidentally edit a read-only file and don't want to change its read-only attribute, I only get the message "File X is readonly!" and I did not find a way except closing and reopening the file to view its context again. Refresh doesn't work and other suggestions I found while searching don't seem to be part of the context menu anymore.
Thanks!
Re: Read-only files [message #901738 is a reply to message #901731] Tue, 14 August 2012 08:24 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
> problems.
> 1)
> http://wiki.eclipse.org/FAQ_What_is_a_label_decorator%3F example,
I don't know of such a plug-in. You would have to implement it yourself.
> 2)
> its context again.
Not exactly sure what you mean with "context". What I see (using the
Text or Java Editor), is the file/content after I click 'No' on the dialog.
Dani
> Thanks!
Re: Read-only files [message #901746 is a reply to message #901738] Tue, 14 August 2012 08:55 Go to previous messageGo to next message
Well I only see a blank page with the specified message. No lines of code...
And I am using Juno.
Re: Read-only files [message #901762 is a reply to message #901746] Tue, 14 August 2012 09:35 Go to previous messageGo to next message
> code...
Then please file a bug report with exact steps to reproduce.
Dani
Re: Read-only files [message #901775 is a reply to message #901762] Tue, 14 August 2012 10:20 Go to previous messageGo to next message
I thought this is the standard behaviour...
Also note, that I only have the C/C++ edition, so I hope it's not only a CDT issue then?
Re: Read-only files [message #901792 is a reply to message #901775] Tue, 14 August 2012 11:17 Go to previous messageGo to next message
> a CDT issue then?
As said, file a bug with the steps ;-)
Dani
Re: Read-only files [message #901812 is a reply to message #901792] Tue, 14 August 2012 12:11 Go to previous message
2)
It seems to be a problem with the VSS plugin (can be found at vssplugin.sourceforge.net). When I tried to reproduce it with a little sample, I found it working just like I expected...
Regarding 1) any ideas?
Previous Topic:Rally Connector
Next Topic:Toggle between source/header: Always
Current Time: Mon May 20 02:16:57 EDT 2013
Powered by FUDForum. Page generated in 0.01987 seconds
