Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] annotations
[TEXO] annotations [message #901770] Tue, 14 August 2012 09:57 Go to next message
Gary Godfrey is currently offline Gary Godfrey
Member
Hi Martin,
Is there a way to have both ORM and code-gen annotations when I generate the code please?
Gary
Re: [TEXO] annotations [message #901802 is a reply to message #901770] Tue, 14 August 2012 11:52 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Gary,
What do you mean with code-gen annotations?
gr. Martin
On 08/14/2012 03:57 PM, Gary Godfrey wrote:
> Hi Martin,
> Gary
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TEXO] annotations [message #901940 is a reply to message #901802] Wed, 15 August 2012 04:26 Go to previous messageGo to next message
Member
Hi Martin,
The current process I follow after generating .ecore file.
1. Generate code gen annotated model. I add a value for root class extends and also mark some entities as transient. File is called xsdmodelname-code-gen.annotationsmodel
2. Generate ORM annotations model. Set 'enforce unique names' to false, set max table name to 30. File is called xsdmodelname-orm.annotationsmodel
I remember in an earlier version I needed to rename the file as xsdmodelname.annotationsmodel for the 'Generate JPA Annotated Code' step to pick up my changes. I have tried merging the changes I have made into a single annotationsmodel but this fails as I have 2 <ePackageAnnotations xsi:type .... and generation fails.
Ideally we want to be able to apply both types of updates during code generation.
Gary
Re: [TEXO] annotations [message #902119 is a reply to message #901940] Thu, 16 August 2012 00:01 Go to previous message
Hi Gary,
The best is to start with an empty annotations model, with only the epackage level annotations for example. Then you can
manually add both codegen and orm annotations in one model (right click on a model element and you will see both
possibilities), only for the eclasses/ereferences you want to override.
With such a minimal annotations model the options also still work for most types (the annotations in the
annotationsmodel override the options).
The idea is that you should only annotate what you want to override, this should ideally only be minimal. If you need a
lot of annotations to accomplish something then let me know, as this is better covered through an option or so.
gr. Martin
On 08/15/2012 10:26 AM, Gary Godfrey wrote:
> Hi Martin,
> Gary
The Netherlands
Previous Topic:[TEXO] JPA entity names
Next Topic:[Texo] Complete tutorial (from scratch)
Current Time: Sat May 18 21:53:00 EDT 2013
Powered by FUDForum. Page generated in 0.01707 seconds
