Home » Eclipse Projects » BIRT » series in radarchart with less than 3 values
series in radarchart with less than 3 values [message #901749] Tue, 14 August 2012 09:01
hage Mising name is currently offline hage Mising name
Member
Hi there,
within my report several radarcharts are generated dynamically. Sometimes the underlying data contains only 1 or 2 datapoints, so the rendered chart contains only one single line (half(1) or across the middle of the chart). In the charts containing more than 2 datapoints, i draw a polygon connecting the points of the series. any ideas what to in case of 1 or 2 points? I tried to increase the thickness of the drawn line using
function beforeDrawSeries( series, isr, icsc )
but that didnt work out. a thickend line drawn in the same color as the polygon would look much more attractive than just a single (rather thin(and black)) line.
thx in advance,
hage
Previous Topic:Colours of dataseries in radarchart
Next Topic:Setting cache in BIRT
Current Time: Sat May 18 18:52:53 EDT 2013
Powered by FUDForum. Page generated in 0.01586 seconds
