Home » Language IDEs » CDT » Problems in modification time( Using "org.eclipse.nebula.widgets.cdatetime.CDateTime " widget to set the time )
Problems in modification time [message #901720] Tue, 14 August 2012 06:25
Shiv Das is currently offline Shiv Das
I am using "org.eclipse.nebula.widgets.cdatetime.CDateTime " widget to set the time but when i go to modify the existing time like hour to "00" then instead of getting modified time, got previous time in that widget.But after modifying hour/minute/second
if we go for modifying any other of these minute/second/hour in the same widget then getting correct modify time and also in the case of focus lost getting the correct value So can anyone please helm me out.Actually i am not sure it's behaving correct or not.
[Updated on: Tue, 14 August 2012 06:40]
Report message to a moderator
Previous Topic:trigonometric functions not known to compiler
Next Topic:Autocomplete speed: Juno vs Indigo
Current Time: Sun May 19 01:42:28 EDT 2013
Powered by FUDForum. Page generated in 0.01554 seconds
