| MultiPageEditor - working with many files, marking MPE as dirty throw exception [message #901717] |
Tue, 14 August 2012 06:15  |
cyriel cysiek Messages: 4 Registered: August 2012 |
Junior Member |
Hi all,
I've got MultiPageEditor in which i've got 5 pages. On first page
there is an editor which extends GraphicalEditor(geEx), on second there are
2(logicInputEditor, logicOutputEditor) GroovyEditor's org.codehaus.groovy.eclipse.editor.GroovyEditor).
geEx is working with one file(e.g. first.qwe) and
logicEditors are working with 2 other files(in.groovy, out.groovy). In
geEx there is a code:
public void commandStackChanged(EventObject event) {
firePropertyChange(IEditorPart.PROP_DIRTY);
super.commandStackChanged(event);
When I edit file first.qwe MultiPageEditor know that something has
been modified and marks it and allow to save file - everything is
fine.
I add listeners to GrooveEditors:
logicInputEditor.addPropertyListener(new IPropertyListener() {
public void propertyChanged(Object source, int propId) {
if (propId == IEditorPart.PROP_DIRTY){
I can't override commandStackChanged function, because GrooveEditor doesn't implement CommandStackListener.
Each time I edit something in one of GroovyEditors, the MultiPageEditor is changing its state to dirty - that's what i wanted, but also exception is printed on console. So - it's working as i want, but throwing and catching exception each time user type someting in editor is propably very
The message is:
Quote:Problem trying to determine classpath of project Test:
Java Model Exception: Java Model Status [Test does not exist]
at org.eclipse.jdt.internal.core.JavaElement.newNotPresentException(JavaElement.java:495)
at org.eclipse.jdt.internal.core.JavaModelManager.getPerProjectInfoCheckExistence(JavaModelManager.java:2287)
at org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo(JavaProject.java:1914)
at org.eclipse.jdt.internal.core.JavaProject.getOutputLocation(JavaProject.java:1741)
at org.eclipse.jdt.core.util.CompilerUtils.calculateClasspath(CompilerUtils.java:209)
at org.eclipse.jdt.core.util.CompilerUtils.setGroovyClasspath(CompilerUtils.java:152)
at org.eclipse.jdt.core.util.CompilerUtils.setGroovyClasspath(CompilerUtils.java:117)
at org.codehaus.jdt.groovy.model.GroovyCompilationUnit.buildStructure(GroovyCompilationUnit.java:260)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:258)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:526)
at org.eclipse.jdt.internal.core.CompilationUnit.makeConsistent(CompilationUnit.java:1100)
at org.codehaus.jdt.groovy.model.GroovyReconcileWorkingCopyOperation.makeConsistent(GroovyReconcileWorkingCopyOperation.java:60)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation.executeOperation(ReconcileWorkingCopyOperation.java:89)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaModelOperation.java:728)
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:788)
at org.codehaus.jdt.groovy.model.GroovyCompilationUnit.reconcile(GroovyCompilationUnit.java:423)
at org.eclipse.jdt.internal.core.CompilationUnit.reconcile(CompilationUnit.java:1231)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:133)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.access$0(JavaReconcilingStrategy.java:108)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy$1.run(JavaReconcilingStrategy.java:89)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:87)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:151)
at org.eclipse.jdt.internal.ui.text.CompositeReconcilingStrategy.reconcile(CompositeReconcilingStrategy.java:86)
at org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStrategy.reconcile(JavaCompositeReconcilingStrategy.java:104)
at org.eclipse.jface.text.reconciler.MonoReconciler.process(MonoReconciler.java:77)
at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:206)
or:
!ENTRY org.eclipse.jdt.core 4 4 2012-08-13 20:33:29.402
!MESSAGE Problem with build structure for in.groovy
!STACK 1
at org.eclipse.jdt.internal.core.JavaElement.newJavaModelException(JavaElement.java:505)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:246)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:255)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:241)
at org.eclipse.jdt.internal.core.JavaProject.getJavaProjectElementInfo(JavaProject.java:1646)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(JavaProject.java:2334)
at org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnvironment.java:59)
at org.eclipse.jdt.internal.core.SearchableEnvironment.<init>(SearchableEnvironment.java:66)
at org.eclipse.jdt.internal.core.CancelableNameEnvironment.<init>(CancelableNameEnvironment.java:26)
at org.eclipse.jdt.internal.core.CompilationUnitProblemFinder.process(CompilationUnitProblemFinder.java:178)
at org.codehaus.jdt.groovy.model.GroovyCompilationUnit.buildStructure(GroovyCompilationUnit.java:338)
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2012-08-13 20:33:29.402
!MESSAGE Test does not exist
The question is - how i can fix this? How should i send 'message' to MultiPageEditor, that one of GroovyEditors is 'dirty'?
Sory for my english
FUDForum. Page generated in 0.02923 seconds
