| Common Navigator Framework [message #901695] |
Tue, 14 August 2012 03:59  |
Priyank Thakkar Messages: 8 Registered: August 2012 |
Junior Member |
I am using Eclipse's common navigator framework. For the pop-up menu within CNF I set the attribute allow-platformcontribution to false. Yet I am not able to remove the pop-up option for Cut, Copy, Paste and Team. How to set them off?
Priyank Thakkar
| Re: Common Navigator Framework [message #902016 is a reply to message #901695] |
Wed, 15 August 2012 09:55  |
Mat Mathiew Messages: 26 Registered: July 2012 |
Junior Member |
You just solved my problem!
For me it works like this and I can see only the contributions I made.
If you don't want the edit you can remove for example :
<insertionPoint
name="group.edit"
separator="true">
</insertionPoint>
<viewer
viewerId="mycustomnavid">
<popupMenu
allowsPlatformContributions="false"
id="mycustomnavid#PopupMenu">
<insertionPoint
name="group.new">
</insertionPoint>
<insertionPoint
name="group.open"
separator="true">
</insertionPoint>
<insertionPoint
name="group.openWith">
</insertionPoint>
<insertionPoint
name="group.edit"
separator="true">
</insertionPoint>
<insertionPoint
name="group.reorganize">
</insertionPoint>
<insertionPoint
name="group.port"
separator="true">
</insertionPoint>
<insertionPoint
name="group.build"
separator="true">
</insertionPoint>
<insertionPoint
name="group.generate"
separator="true">
</insertionPoint>
<insertionPoint
name="group.search"
separator="true">
</insertionPoint>
<insertionPoint
name="additions"
separator="true">
</insertionPoint>
<insertionPoint
name="group.properties"
separator="true">
</insertionPoint>
</popupMenu>
</viewer>
[Updated on: Wed, 15 August 2012 09:58] Report message to a moderator
FUDForum. Page generated in 0.04267 seconds
