Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Selection Listener on TabFolder executing five times on each click?
Selection Listener on TabFolder executing five times on each click? [message #901576] Mon, 13 August 2012 09:38
Michael Dougherty is currently offline Michael Dougherty
I want to add a listener that does something when you change tabs with the selection listener.
I am doing something where if you edit something on a tab and don't save, if you attempt to change tabs it will stay on the original tab (I did this by getting the current Tab and resetting it to that one after you change) and a pop up comes up telling you to save or cancel your changes.
I realized however that this popup was coming up FIVE times in a row when you changed tabs, and with a println statement I see that for some reason it goes into the selection listener five times? Why is this and how can I fix it?
Previous Topic:StyledText location at offset on word wrap problem
Next Topic:Maximum width of a control?
Current Time: Sat May 25 21:40:15 EDT 2013
Powered by FUDForum. Page generated in 0.01389 seconds
