Home » Eclipse Projects » Jubula » Can't use Excel as data source!(When i use Excel as my data source Jubula tells me "Test data for this node is incomplete".)
Can't use Excel as data source! [message #901037] Thu, 09 August 2012 09:56 Go to next message
Andreas Gruber is currently offline Andreas Gruber
Hello
I work with Jubula now a view weeks but I can't solve this.
When I input a path to an Excel document my module get market erroneous and I can't start my test anymore.
If I try things like this:
* Comment the erroneous module out
* Save
* Comment the erroneous module in
* NOT save
* Execute the test
It is possible that the Error sign disappears.
The Error is solved also when I restart Jubula.
So it is possible that I have two modules which are equal and one is correct and one is erroneous.
What do I wrong.
Thanks for helping.
Andreas
Version: 1.2.1 (Standalone)
Bug: Test data for this node is incomplete.
Excel version: 2010
OS: Windows 7
[Updated on: Thu, 09 August 2012 10:02]
Report message to a moderator
Re: Can't use Excel as data source! [message #901494 is a reply to message #901037] Mon, 13 August 2012 03:18 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
It sounds like you may have run into this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=386368
There is a workaround described on the ticket that may help for now.
Alex
Re: Can't use Excel as data source! [message #901514 is a reply to message #901494] Mon, 13 August 2012 04:28 Go to previous message
Thank you for your help.
Previous Topic:Jubula: Rename a GMF element
Next Topic:Installing previous versions of Jubula?
Current Time: Sun May 26 05:00:57 EDT 2013
Powered by FUDForum. Page generated in 0.04585 seconds
