| IDE closes when accessing help [message #901431] |
Sun, 12 August 2012 03:13  |
Bob NIcholson Messages: 62 Registered: December 2011 Location: Seattle |
Member |
I've just installed a new version of EDT today. Every time I try to access Help, my IDE closes down.
When the IDE fails, I get the attached error. I'm not sure if this could be causing the problem. Unfortunately, I don't understand the error.
Bob
[Updated on: Sun, 12 August 2012 11:11] Report message to a moderator
| Re: IDE closes when accessing help [message #901644 is a reply to message #901642] |
Mon, 13 August 2012 15:31   |
Member |
1) What version of the installation are you using? (i.e. All in One, Update Site for a JEE Eclipse, etc) I believe this is the All in One. Eclipse and EGL all came down in one package. eglweb-081-win32-x86_64.zip
2) Did you upgrade your installation from an older build, or is this a new installation? This is all new.
3) How are you accessing the Help system? (i.e. Help->Help Contents, etc) Either Help Contents or search. Select either and it comes up for a couple of seconds and then everything ends.
4) Are you able to recreate this consistently? I believe you said you are, but I wanted to confirm. Yes, every time.
[Updated on: Mon, 13 August 2012 15:32] Report message to a moderator
| Re: IDE closes when accessing help [message #902108 is a reply to message #902091] |
Wed, 15 August 2012 17:41  |
Member |
Hopefully this is what you are looking for:
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Users\Bob\Downloads\Eclipse\eglweb-081-win32-x86_64\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
java.class.version=51.0
java.endorsed.dirs=C:\Program Files\Java\jre7\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre7\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre7
java.io.tmpdir=C:\Users\Bob\AppData\Local\Temp\
java.library.path=C:\Windows\system32;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\PROGRA~2\IBM\CLIENT~1\Shared;C:\Program Files (x86)\Common Files\HP\Digital Imaging\bin;C:\Program Files (x86)\HP\Digital Imaging\bin\;C:\Program Files (x86)\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files (x86)\IBM\Client Access\Emulator;C:\Program Files (x86)\IBM\Client Access\Shared;C:\Program Files (x86)\IBM\Client Access\;C:\Program Files (x86)\IBM\SDP\bin;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0-b147
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=21.0-b17
FUDForum. Page generated in 0.01847 seconds
