Home » Eclipse Projects » Eclipse Platform » unable to use secure storage with headless antRunner app
unable to use secure storage with headless antRunner app [message #901406] Sat, 11 August 2012 17:41
Vlad Gheorghe is currently offline Vlad Gheorghe
Member
Hi all,
I'm trying to use the antRunner application in order to mirror some sites into my company's intranet. The setup requires to authenticate to a http proxy.
I'm using Eclipse Platform 3.7.2.
The command line is like :
$ eclipse -data ./ws -eclipse.password ./passwd -consoleLog  -noSplash \
    -application org.eclipse.ant.core.antRunner -f t.xml mirror
!SESSION 2012-08-12 00:11:43.141 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_29
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments:  -eclipse.password ./passwd -application org.eclipse.ant.core.antRunner -f t.xml mirror
Command-line arguments:  -os linux -ws gtk -arch x86 -data ./ws -eclipse.password ./passwd -consoleLog -application org.eclipse.ant.core.antRunner -f t.xml mirror
!ENTRY org.eclipse.core.resources 2 10035 2012-08-12 00:11:44.604
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
Unknown argument: -eclipse.password
Unknown target: ./passwd
Buildfile: t.xml
mirror:
In the end there is a proxy authentication error, and the process stops.
Note that starting the UI with -eclipse.password ./passwd allows the eclipse instance to connect over the proxy.
Why is the parameter -eclipse.pasword reported as unknown ?
Also, the message "Unknown target: ./passwd" indicates that actually these parameters are interpreted by antRunner, and not eqinox.
Any suggestions would be greatly appreciated.
Vlad
Previous Topic:Configure default line separator through plugin customization
Next Topic:Progress bar of progress group disappears
Current Time: Sun May 19 04:14:39 EDT 2013
Powered by FUDForum. Page generated in 0.11154 seconds
