Home » Eclipse Projects » Equinox » Help find documentation - Export-Package: split
Help find documentation - Export-Package: split [message #90138] Mon, 11 June 2007 11:15 Go to next message
ilan klein is currently offline ilan klein
Hi all,
I asked a questinon in the platform newsgroup, and they mentioned I should
come and ask about it here.
The problem was how to tell eclipse that I want to share the same packe from
2 separate plugins.
This is similar to this question here:
http://www.eclipsezone.com/eclipse/forums/t96309.html
The problem was that I have an interface pluginand an implementation plugin.
Both export the same package structure - "pluginone".
There is a user plugin which uses them with "Import Package:" statement.
The answer was to use - Export-Package: pluginone; common="split";
mandatory:="common"
I have attached 3 plugins for showing the problem and solution, now I need
to undersatnd what the change means.
Can you point me to the Export-Paxkage documentation showing the split, and
common ... since I was not able to find it.
Thanks.
Re: Help find documentation - Export-Package: split [message #90330 is a reply to message #90138] Tue, 12 June 2007 09:04 Go to previous messageGo to next message
Brett Humphreys is currently offline Brett Humphreys
Ilan,
I would suggest reading the OSGi R4 spec (which you can request to
download from www.osgi.org), it goes into detail about what the
mandatory directive does and how it is used.
That being said, I was under the impression that when you have a split
package like you do (similar to the equinox common bundle, which is
split for legacy reasons I believe), you must use the 'require-bundle'
header and not the 'import-package' header. Section 3.13.2 of the R4
spec discusses this a bit, as well as the disadvantages of using this
header.
-Brett
Ilan Klein wrote:
> Hi all,
> 2 separate plugins.
> mandatory:="common"
> Thanks.
Re: Help find documentation - Export-Package: split [message #90493 is a reply to message #90330] Wed, 13 June 2007 15:03 Go to previous messageGo to next message
Thomas Watson is currently offline Thomas Watson
For a good example look at the following bundles in the Eclipse SDK
org.eclipse.equinox.common
org.eclipse.equinox.registry
org.eclipse.core.runtime
They contain the following exports
Bundle-SymbolicName: org.eclipse.equinox.common
Export-Package: org.eclipse.core.runtime;
common="split";
mandatory:="common"
Bundle-SymbolicName: org.eclipse.equinox.registry
registry="split";
mandatory:="registry",
Require-Bundle: org.eclipse.equinox.common
Bundle-SymbolicName: org.eclipse.core.runtime
Require-Bundle: org.eclipse.equinox.common, org.eclipse.equinox.registry
In this case it was decided to split the org.eclipse.core.runtime
package across 3 bundles. A set of "common" classes from the package
were placed in the bundle org.eclipse.equinox.common, a set of
"registry" related classes were placed in the bundle
org.eclipse.equinox.registry and the rest remained in the bundle
The mandatory directive was used to force importers of the
org.eclipse.core.runtime package to make a explicit choose to get wired
to a "partial" part of the split package. Require-Bundle is used by the
org.eclipse.core.runtime and org.eclipse.equinox.registry bundles in
order to combined parts of the split package and export the parts
together as on package. For example:
Import-Package: org.eclipse.core.runtime; common="split"
Will wire your bundle to only the part exported by the
org.eclipse.equinox.common bundle.
Import-Package: org.eclipse.core.runtime; registry="split"
org.eclipse.equinox.registry bundle, but in this case the registry
bundle uses Require-Bundle to combined the content from the common
bundle into the export from the registry bundle. So your bundle will
have access to both the content from registry and common.
This cannot wire to the export from common or registry because it does
not use the mandatory attr required to wire to either of these packages.
This will wire your bundle to the part exported by the
org.eclipse.core.runtime bundle. The runtime bundle combines the parts
from common and registry and exports the "complete" package as it was
before the package was split.
HTH
Tom.
Re: Help find documentation - Export-Package: split [message #90597 is a reply to message #90138] Wed, 13 June 2007 16:44 Go to previous message
Eclipse User
Originally posted by: alex_blewitt.yahoo.com
I put some documentation on this here:
http://www.eclipsezone.com/eclipse/forums/t97259.html
As well as answering in the original thread :-)
Alex.
Previous Topic:Error on "Starting Eclipse Commandline With Equinox Launcher" web page
Next Topic:Access EJB in JBOSS from OSGI
Current Time: Sun May 19 06:43:11 EDT 2013
Powered by FUDForum. Page generated in 0.01741 seconds
