Home » Eclipse Projects » BIRT » Dynamically generate pie chart in script
Dynamically generate pie chart in script [message #901128] Thu, 09 August 2012 17:56 Go to next message
zubin Missing name is currently offline zubin Missing name
Member
Following are my code to create in script, and i am getting following error when I try it on eclipse 4.2:
ReferenceError: "ChartWithAxesImpl" is not defined. (/report/method[@name="beforeFactory"]#168)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:295)
it seems i am missing jar file on my path, any other thought? thx
importPackage( Packages.org.eclipse.birt.report.model.api );
importPackage( Packages.org.eclipse.birt.chart.model.impl );
var pieChartComponent = elementFactory.newExtendedItem( null, "Chart" );
pieChartComponent.setHeight( "5.406in" );//$NON-NLS-1$
pieChartComponent.setWidth( "7.927in" );//$NON-NLS-1$
pieChartComponent.setProperty( "dataSet", "CampaignSummaryQuery" );//$NON-NLS-1$
pieChartComponent.setProperty( "chart.instance", createMultiYAxisChart( ) );
reportDesignHandle.getBody( ).add(pieChartComponent);
function createMultiYAxisChart( )
cwaBar = ChartWithAxesImpl.create( );
// Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
245,
255 ) );
// Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Line Chart with Multiple Y Axis" );//$NON-NLS-1$
// Legend
lg = cwaBar.getLegend( );
lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.getOutline( ).setVisible( false );
lg.setAnchor( Anchor.NORTH_LITERAL );
// X-Axis
xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getTitle( ).setVisible( false );
// Y-Axis
yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
yAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Sales Growth ($Million)" );//$NON-NLS-1$
// Y-Axis (2)
yAxis = AxisImpl.create( Axis.ORTHOGONAL );
yAxis.setType( AxisType.LINEAR_LITERAL );
yAxis.getMajorGrid( ).setTickStyle( TickStyle.RIGHT_LITERAL );
yAxis.setLabelPosition( Position.RIGHT_LITERAL );
xAxisPrimary.getAssociatedAxes( ).add( yAxis );
// Data Set
// TextDataSet categoryValues = TextDataSetImpl.create( new String[]{
// "March", "April", "May", "June", "July"} );//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
// NumberDataSet orthoValues1 = NumberDataSetImpl.create( new double[]{
// 12.5, 19.6, 18.3, 13.2, 26.5
// NumberDataSet orthoValues2 = NumberDataSetImpl.create( new double[]{
// 22.7, 23.6, 38.3, 43.2, 40.5
// X-Series
seCategory = SeriesImpl.create( );
query = QueryImpl.create( "row[\"ProductLine\"]" );//$NON-NLS-1$
seCategory.getDataDefinition( ).add( query );
// seCategory.setDataSet( categoryValues );
sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series (1)
ls1 = LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "A Corp." );//$NON-NLS-1$
query1 = QueryImpl.create( "row[\"buyprice\"]" );//$NON-NLS-1$
ls1.getDataDefinition( ).add( query1 );
//ls1.setDataSet( orthoValues1 );
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.CREAM( ) );
ls1.getMarker( ).setType( MarkerType.TRIANGLE_LITERAL );
ls1.getMarker( ).setSize( 10 );
ls1.getLabel( ).setVisible( true );
sdY1 = SeriesDefinitionImpl.create( );
sdY1.getSeriesPalette( ).update( -2 );
yAxisPrimary.getSeriesDefinitions( ).add( sdY1 );
sdY1.getSeries( ).add( ls1 );
// Y-Serires (2)
ls2 = LineSeriesImpl.create( );
ls2.setSeriesIdentifier( "B Corp." );//$NON-NLS-1$
query2 = QueryImpl.create( "row[\"quantityinstock\"]" );//$NON-NLS-1$
ls1.getDataDefinition( ).add( query2 );
// ls2.setDataSet( orthoValues2 );
ls2.getLineAttributes( ).setColor( ColorDefinitionImpl.CREAM( ) );
ls2.getMarker( ).setType( MarkerType.CIRCLE_LITERAL );
ls2.getMarker( ).setSize( 10 );
ls2.getLabel( ).setVisible( true );
sdY2 = SeriesDefinitionImpl.create( );
sdY2.getSeriesPalette( ).update( -3 );
yAxis.getSeriesDefinitions( ).add( sdY2 );
sdY2.getSeries( ).add( ls2 );
return cwaBar;
Re: Dynamically generate pie chart in script [message #901260 is a reply to message #901128] Fri, 10 August 2012 10:05 Go to previous messageGo to next message
Member
The following example actually tried to created an bar chart. but the same issue will happens when creating bar chart. How can I use chart api in script?
I added the chart engine jar to be included in report jar file section and imported all of following to script:
importPackage( Packages.com.coresecuirty.report );
importPackage( Packages.org.eclipse.birt.chart.model.attribute.impl );
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
importPackage( Packages.org.eclipse.birt.chart.model.component.impl );
importPackage( Packages.org.eclipse.birt.chart.model.component );
importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
importPackage( Packages.org.eclipse.birt.chart.model.type.impl );
But I am keep getting this error:
ReferenceError: "ChartWithAxesImpl" is not defined. (/report/method[@name="beforeFactory"]#180)
Re: Dynamically generate pie chart in script [message #901327 is a reply to message #901128] Fri, 10 August 2012 16:05 Go to previous messageGo to next message
Member
pieChartComponent.getReportItem().setProperty( "chart.instance", createPieChart());
function createPieChart()
cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setDimension( ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL );
cwoaPie.setType( "Pie Chart" ); //$NON-NLS-1$
cwoaPie.setSubType( "Standard Pie Chart" ); //$NON-NLS-1$
// Plot
cwoaPie.setSeriesThickness( 10 );
// Legend
lg = cwoaPie.getLegend( );
lg.getOutline( ).setVisible( true );
// Title
cwoaPie.getTitle( ).getLabel( ).getCaption( ).setValue( "Pie Chart" );//$NON-NLS-1$
// Data Set
categoryValues = TextDataSetImpl.create( new Array(
"New York", "Boston", "Chicago", "San Francisco", "Dallas") );//$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
seriesOneValues = NumberDataSetImpl.create( new Array(
54.65, 21, 75.95, 91.28, 37.43
sdata = DataFactory.eINSTANCE.createSampleData( );
sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "" );//$NON-NLS-1$
sdata.getBaseSampleData( ).add( sdBase );
sdOrthogonal = DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sdata.getOrthogonalSampleData( ).add( sdOrthogonal );
cwoaPie.setSampleData( sdata );
// Base Series
sd = SeriesDefinitionImpl.create( );
cwoaPie.getSeriesDefinitions( ).add( sd );
sd.getSeriesPalette( ).shift( 0 );
sd.getSeries( ).add( seCategory );
// Orthogonal Series
sePie = PieSeriesImpl.create( );
sePie.setDataSet( seriesOneValues );
sePie.setSeriesIdentifier( "Cities" );//$NON-NLS-1$
sePie.setExplosion( 5 );
sdCity = SeriesDefinitionImpl.create( );
sd.getSeriesDefinitions( ).add( sdCity );
sdCity.getSeries( ).add( sePie );
return cwoaPie;
-------------------------------error----------------------------------
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.GeneratedMethodAccessor140.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2248)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
... 55 more
Caused by: java.lang.NullPointerException
at org.eclipse.birt.chart.reportitem.api.ChartItemUtil.isBaseGroupingDefined(ChartItemUtil.java:570)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.createBaseGroupingDefinition(AbstractChartBaseQueryGenerator.java:877)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.initCategoryGrouping(AbstractChartBaseQueryGenerator.java:645)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.generateExtraBindings(AbstractChartBaseQueryGenerator.java:336)
at org.eclipse.birt.chart.reportitem.ChartBaseQueryHelper.createBaseQuery(ChartBaseQueryHelper.java:106)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createQuery(ChartReportItemQueryImpl.java:171)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createReportQueries(ChartReportItemQueryImpl.java:107)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java:689)
at org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept(ExtendedItemDesign.java:45)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:256)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:237)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(AbstractDataEngine.java:180)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:122)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:178)
... 57 more
Re: Dynamically generate pie chart in script [message #901612 is a reply to message #901327] Mon, 13 August 2012 12:21 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Take a look at the attached example.
Jason
> // Plot
> // Legend
> // Title
> // Data Set
> //$NON-NLS-5$
> sdOrthogonal =
> // Base Series
> return cwoaPie;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
Jason Weathersby
BIRT Exchange
Re: Dynamically generate pie chart in script [message #1051948 is a reply to message #901612] Mon, 29 April 2013 08:12 Go to previous message
Alon R is currently offline Alon R
The attached example does generate the report however Eclipse 4.2 still complains with the same error message.
It there something different about Bar charts? Can you please add an example that shows how to create one?
Thanks a lot.
Previous Topic:Custom emitter configuring
Next Topic:BIRT report with chinese titles in chart
Current Time: Sat May 25 17:47:01 EDT 2013
Powered by FUDForum. Page generated in 0.01748 seconds
