| Dynamically generate pie chart in script [message #901128] |
Thu, 09 August 2012 17:56  |
zubin Missing name Messages: 32 Registered: July 2009 |
Member |
Following are my code to create in script, and i am getting following error when I try it on eclipse 4.2:
ReferenceError: "ChartWithAxesImpl" is not defined. (/report/method[@name="beforeFactory"]#168)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:295)
it seems i am missing jar file on my path, any other thought? thx
importPackage( Packages.org.eclipse.birt.report.model.api );
importPackage( Packages.org.eclipse.birt.chart.model.impl );
var pieChartComponent = elementFactory.newExtendedItem( null, "Chart" );
pieChartComponent.setHeight( "5.406in" );//$NON-NLS-1$
pieChartComponent.setWidth( "7.927in" );//$NON-NLS-1$
pieChartComponent.setProperty( "dataSet", "CampaignSummaryQuery" );//$NON-NLS-1$
pieChartComponent.setProperty( "chart.instance", createMultiYAxisChart( ) );
reportDesignHandle.getBody( ).add(pieChartComponent);
function createMultiYAxisChart( )
cwaBar = ChartWithAxesImpl.create( );
// Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
245,
255 ) );
// Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Line Chart with Multiple Y Axis" );//$NON-NLS-1$
// Legend
lg = cwaBar.getLegend( );
lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.getOutline( ).setVisible( false );
lg.setAnchor( Anchor.NORTH_LITERAL );
// X-Axis
xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getTitle( ).setVisible( false );
// Y-Axis
yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
yAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Sales Growth ($Million)" );//$NON-NLS-1$
// Y-Axis (2)
yAxis = AxisImpl.create( Axis.ORTHOGONAL );
yAxis.setType( AxisType.LINEAR_LITERAL );
yAxis.getMajorGrid( ).setTickStyle( TickStyle.RIGHT_LITERAL );
yAxis.setLabelPosition( Position.RIGHT_LITERAL );
xAxisPrimary.getAssociatedAxes( ).add( yAxis );
// Data Set
// TextDataSet categoryValues = TextDataSetImpl.create( new String[]{
// "March", "April", "May", "June", "July"} );//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
// NumberDataSet orthoValues1 = NumberDataSetImpl.create( new double[]{
// 12.5, 19.6, 18.3, 13.2, 26.5
// NumberDataSet orthoValues2 = NumberDataSetImpl.create( new double[]{
// 22.7, 23.6, 38.3, 43.2, 40.5
// X-Series
seCategory = SeriesImpl.create( );
query = QueryImpl.create( "row[\"ProductLine\"]" );//$NON-NLS-1$
seCategory.getDataDefinition( ).add( query );
// seCategory.setDataSet( categoryValues );
sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series (1)
ls1 = LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "A Corp." );//$NON-NLS-1$
query1 = QueryImpl.create( "row[\"buyprice\"]" );//$NON-NLS-1$
ls1.getDataDefinition( ).add( query1 );
//ls1.setDataSet( orthoValues1 );
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.CREAM( ) );
ls1.getMarker( ).setType( MarkerType.TRIANGLE_LITERAL );
ls1.getMarker( ).setSize( 10 );
ls1.getLabel( ).setVisible( true );
sdY1 = SeriesDefinitionImpl.create( );
sdY1.getSeriesPalette( ).update( -2 );
yAxisPrimary.getSeriesDefinitions( ).add( sdY1 );
sdY1.getSeries( ).add( ls1 );
// Y-Serires (2)
ls2 = LineSeriesImpl.create( );
ls2.setSeriesIdentifier( "B Corp." );//$NON-NLS-1$
query2 = QueryImpl.create( "row[\"quantityinstock\"]" );//$NON-NLS-1$
ls1.getDataDefinition( ).add( query2 );
// ls2.setDataSet( orthoValues2 );
ls2.getLineAttributes( ).setColor( ColorDefinitionImpl.CREAM( ) );
ls2.getMarker( ).setType( MarkerType.CIRCLE_LITERAL );
ls2.getMarker( ).setSize( 10 );
ls2.getLabel( ).setVisible( true );
sdY2 = SeriesDefinitionImpl.create( );
sdY2.getSeriesPalette( ).update( -3 );
yAxis.getSeriesDefinitions( ).add( sdY2 );
sdY2.getSeries( ).add( ls2 );
return cwaBar;
| Re: Dynamically generate pie chart in script [message #901327 is a reply to message #901128] |
Fri, 10 August 2012 16:05   |
Member |
pieChartComponent.getReportItem().setProperty( "chart.instance", createPieChart());
function createPieChart()
cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setDimension( ChartDimension.TWO_DIMENSIONAL_WITH_DEPTH_LITERAL );
cwoaPie.setType( "Pie Chart" ); //$NON-NLS-1$
cwoaPie.setSubType( "Standard Pie Chart" ); //$NON-NLS-1$
// Plot
cwoaPie.setSeriesThickness( 10 );
// Legend
lg = cwoaPie.getLegend( );
lg.getOutline( ).setVisible( true );
// Title
cwoaPie.getTitle( ).getLabel( ).getCaption( ).setValue( "Pie Chart" );//$NON-NLS-1$
// Data Set
categoryValues = TextDataSetImpl.create( new Array(
"New York", "Boston", "Chicago", "San Francisco", "Dallas") );//$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
seriesOneValues = NumberDataSetImpl.create( new Array(
54.65, 21, 75.95, 91.28, 37.43
sdata = DataFactory.eINSTANCE.createSampleData( );
sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "" );//$NON-NLS-1$
sdata.getBaseSampleData( ).add( sdBase );
sdOrthogonal = DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sdata.getOrthogonalSampleData( ).add( sdOrthogonal );
cwoaPie.setSampleData( sdata );
// Base Series
sd = SeriesDefinitionImpl.create( );
cwoaPie.getSeriesDefinitions( ).add( sd );
sd.getSeriesPalette( ).shift( 0 );
sd.getSeries( ).add( seCategory );
// Orthogonal Series
sePie = PieSeriesImpl.create( );
sePie.setDataSet( seriesOneValues );
sePie.setSeriesIdentifier( "Cities" );//$NON-NLS-1$
sePie.setExplosion( 5 );
sdCity = SeriesDefinitionImpl.create( );
sd.getSeriesDefinitions( ).add( sdCity );
sdCity.getSeries( ).add( sePie );
return cwoaPie;
-------------------------------error----------------------------------
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.GeneratedMethodAccessor140.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2248)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
... 55 more
Caused by: java.lang.NullPointerException
at org.eclipse.birt.chart.reportitem.api.ChartItemUtil.isBaseGroupingDefined(ChartItemUtil.java:570)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.createBaseGroupingDefinition(AbstractChartBaseQueryGenerator.java:877)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.initCategoryGrouping(AbstractChartBaseQueryGenerator.java:645)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.generateExtraBindings(AbstractChartBaseQueryGenerator.java:336)
at org.eclipse.birt.chart.reportitem.ChartBaseQueryHelper.createBaseQuery(ChartBaseQueryHelper.java:106)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createQuery(ChartReportItemQueryImpl.java:171)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createReportQueries(ChartReportItemQueryImpl.java:107)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuilderVisitor.visitExtendedItem(ReportQueryBuilder.java:689)
at org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept(ExtendedItemDesign.java:45)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:256)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(ReportQueryBuilder.java:237)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(AbstractDataEngine.java:180)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:122)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:178)
... 57 more
| Re: Dynamically generate pie chart in script [message #901612 is a reply to message #901327] |
Mon, 13 August 2012 12:21   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Take a look at the attached example.
Jason
> // Plot
> // Legend
> // Title
> // Data Set
> //$NON-NLS-5$
> sdOrthogonal =
> // Base Series
> return cwoaPie;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
Jason Weathersby
BIRT Exchange
| Re: Dynamically generate pie chart in script [message #1051948 is a reply to message #901612] |
Mon, 29 April 2013 08:12  |
Alon R Messages: 1 Registered: April 2013 |
Junior Member |
The attached example does generate the report however Eclipse 4.2 still complains with the same error message.
It there something different about Bar charts? Can you please add an example that shows how to create one?
Thanks a lot.
FUDForum. Page generated in 0.01813 seconds
