Home » Eclipse Projects » BIRT » Setting the value of the value of the page variable to the value of the computed column in dataset
Setting the value of the value of the page variable to the value of the computed column in dataset [message #900798] Wed, 08 August 2012 10:03 Go to next message
Rupal Biyani is currently offline Rupal Biyani
I want to set the value of a page variable to the value of the computed column on the onFetch script of the dataset.But it doesnt seeme to work.
Can you help me on that?
Re: Setting the value of the value of the page variable to the value of the computed column in datas [message #900833 is a reply to message #900798] Wed, 08 August 2012 12:33 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Rupal,
The onFetch is not a good location to set a page variable as all the
onFetch events may be call prior to creating the first page. Can you
give some more detail on what you are trying to do and we can propose a
different method of doing it.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Order by clause
Next Topic:CDT Custom build Option to be added in Projects Context Menu and run for Both MBS and Standard Make
Current Time: Sat May 25 22:35:52 EDT 2013
Powered by FUDForum. Page generated in 0.09006 seconds
