| Microsoft Office Excel Injector does not produce output [message #900379] |
Mon, 06 August 2012 13:52  |
Marcio Oliveira Messages: 50 Registered: June 2010 |
Member |
I am starting with ATL.
After have executed the ATL Example (public2private) provided in the Eclipse Juno,
I tried to run the Microsoft Office Excel Injector from the ATL Transformations Zoo.
It seems to be simple: unpack the sources, create the ATL project and run the example.
The ATL Luncher found the metamodels. But I also tried to give the path to them.
However, in both cases the generated output was an XML file with two lines,
no data. Only the xml header and xmi header tags.
There is some incompatibility of this example with Eclipse Juno or I missed something?
Thanks in advance for the help
FUDForum. Page generated in 0.01982 seconds
