Home » Modeling » GMF (Graphical Modeling Framework) » Problem in generating Code
| Problem in generating Code [message #900333] |
Mon, 06 August 2012 10:22  |
Sarath Rachakonda Messages: 15 Registered: May 2012 |
Junior Member |
Hi Everyone,
Iam trying to generate code for simple GMF model mentioned in ttp://gmfsamples.tuxfamily.org/wiki/doku.php?id=gmf_tutorial1
Iam using eclipse juno (latest stable release - Eclipse Juno (4.2) Package)
When i try to generate diagram code iam getting following error
Problems while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 18) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 77) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 83) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 19) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in CodeStyle, line 49) while generating code
Exception (Boolean expected (was: org.eclipse.ocl.ecore.internal.OCLStandardLibraryImpl$1)!:in xpt::plugin::manifest, line 78) while generating code
Your help is appreciated
Sarath
Attachment: file.genmodel
(Size: 1.51KB, Downloaded 27 times)
Attachment: file.gmfgraph
(Size: 2.44KB, Downloaded 30 times)
Attachment: file.gmfmap
(Size: 2.41KB, Downloaded 23 times)
Attachment: file.gmftool
(Size: 1.52KB, Downloaded 27 times)
Attachment: file.gmfgen
(Size: 15.94KB, Downloaded 25 times)
[Updated on: Tue, 07 August 2012 08:06] Report message to a moderator
| Re: Problem in generating Code [message #1011833 is a reply to message #901020] |
Wed, 20 February 2013 05:34  |
Stephan Schmidt Messages: 1 Registered: February 2013 Location: Berlin, Germany |
Junior Member |
A coworker and myself experienced this problem independently of each other. Problems like these are very frustrating, as it is nigh impossible to find proper documentation for these issues. At the current stage, it seems the state of the GMF documentation is quite poor. People interested in GMF still learn through the tutorials (which do a good job at introducing to GMF), but then you are on your own.
In my opinion, it would be helpful to have a central location for all documentation - API, Tutorials, Howtos, Explanation of GMFModel file properties (gmfmap, gmfgen, ...). At the moment, the wiki is in a very unorganized state. I don't know if this is due to the migration from an old wiki or what is the issue here - many dead links, empty pages and so on.
Hopefully I don't come across as overly negative here - I am truly thankful for GMF and its contributors, and it is a great tool - if you know what you are doing! But growing the userbase will be difficult if frustrations like this occur, where solutions are found only in newsgroups instead of comprehensive documentation/FAQs.
Stephan
Current Time: Wed May 22 15:27:26 EDT 2013
Powered by FUDForum. Page generated in 0.04551 seconds
