Home » Eclipse Projects » P2 » p2 and UAC
p2 and UAC [message #900605] Tue, 07 August 2012 14:25 Go to next message
Timothy Vogel is currently offline Timothy Vogel
Member
Is there anyone that can help me setup an RCP application on Windows 7 / Vista when the application is installed in \Program Files directory? The user is not running as admin and p2 is failing with can't find update sites. When the same install is run targeting a non-controlled directory, the update works correctly.
My google searches have returned others with the same problem but no clear answer on how to resolve.
Re: p2 and UAC [message #900616 is a reply to message #900605] Tue, 07 August 2012 15:11 Go to previous message
Pascal Rapicault is currently offline Pascal Rapicault
This is because p2 does not find the update sites listed in the read only folder. You can try applying the patch attached to bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=249133 but at this point I have not tried it though the author says that he used this in production.
Previous Topic:How is installFeature action supposed to work?
Next Topic:NL Fragment deployment
Current Time: Fri May 24 20:56:51 EDT 2013
Powered by FUDForum. Page generated in 0.01527 seconds
