| Clean doesn't work as expected [message #900458] |
Tue, 07 August 2012 03:54  |
Chen Fliesher Messages: 8 Registered: July 2012 |
Junior Member |
I am trying to clean Virgo 3.5 on Tomcat and it appears it doesn't do a full clean.
The clean does remove serviceablity and work directory. However, the indication that clean doesn't work is for 2 reasons:
1. The index of bundles after start up is 0,38,63... 160
2. On OSGI console use of packages brings bundles with unrelevant index, see below.
org.osgi.util.tracker; version="1.5.1"<org.eclipse.osgi_3.8.0.v20120508-2119 [0]>
org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744 [1] imports
org.apache.felix.gogo.command_0.8.0.v201108120515 [9] imports
org.apache.felix.gogo.runtime_0.8.0.v201108120515 [10] imports
org.apache.felix.gogo.shell_0.8.0.v201110170705 [11] imports
org.eclipse.equinox.cm_1.0.400.v20120319-2029 [14] imports
org.eclipse.equinox.common_3.6.100.v20120509-1351 [15] imports
org.eclipse.equinox.console_1.0.0.v20120511-0559 [16] imports
org.eclipse.equinox.console.ssh_1.0.0.v20120430-1356 [17] imports
org.eclipse.equinox.ds_1.4.0.v20120112-1400 [18] imports
org.eclipse.equinox.event_1.2.100.v20111010-1614 [19] imports
org.eclipse.equinox.region_1.1.0.v20120319-1602 [20] imports
org.eclipse.equinox.util_1.0.300.v20111010-1614 [21] imports
osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.0.v20120508-2119
38 ACTIVE org.eclipse.virgo.kernel.userregionfactory_3.5.0.RELEASE
63 ACTIVE org.eclipse.equinox.cm_1.0.400.v20120319-2029
64 ACTIVE org.eclipse.virgo.kernel.userregion_3.5.0.RELEASE
65 ACTIVE org.eclipse.virgo.kernel.osgicommand_3.5.0.RELEASE
66 ACTIVE org.eclipse.osgi.services_3.3.0.v20120307-2102
67 RESOLVED osgi.enterprise_4.2.0.v201108120515
68 ACTIVE org.eclipse.gemini.management_1.0.2.RELEASE
Fragments=69
69 RESOLVED org.eclipse.virgo.management.fragment_3.5.0.RELEASE
Master=68
70 ACTIVE org.apache.mina.core_2.0.2.v201108120515
71 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
72 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
73 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
Any idea, how to clean virgo otherwise ?
FUDForum. Page generated in 0.01649 seconds
