Home » Eclipse Projects » Voicetools » VTP 3.0 M5 Install Help
VTP 3.0 M5 Install Help [message #900388] Mon, 06 August 2012 15:53 Go to next message
Cecil Vermule is currently offline Cecil Vermule
When I put the jars in my Eclipse installation and try to open it I get the following error.
Any ideas on what is wrong?
Message: Unable to create editor ID org.eclipse.vtp.desktop.editors.voice.editor.VoiceEditor: An exception was thrown during initialization
Session Data: eclipse.buildId=M20120208-0800
java.version=1.6.0_11
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
Exception Stack Trace:java.lang.NullPointerException
at org.eclipse.vtp.desktop.editors.voice.editor.VoiceEditor.init(VoiceEditor.java:64)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:331)
at org.eclipse.ui.actions.OpenWithMenu$3.handleEvent(OpenWithMenu.java:215)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: VTP 3.0 M5 Install Help [message #900490 is a reply to message #900388] Tue, 07 August 2012 05:40 Go to previous messageGo to next message
Kevin Smith is currently offline Kevin Smith
Not sure what the problem is... however version 3.0 is very old now and lacks many features, unless you really need that version I would follow the instructions at www.eclipse.org/forums/index.php/t/319046/ and install version 4.0.
icon14.gif  Re: VTP 3.0 M5 Install Help [message #900557 is a reply to message #900490] Tue, 07 August 2012 10:02 Go to previous message
Thanks for the help. When you go to the VTP downloads page it says that the latest build is 3.0 (http://www.eclipse.org/vtp/downloads.php). I was able to get it installed with your help as version 4.0.
Previous Topic:Generating Vxml2.0 using OpenVxml4.0
Next Topic:Doubt in Advanced Transfer and WebService
Current Time: Sat May 25 13:47:32 EDT 2013
Powered by FUDForum. Page generated in 0.01510 seconds
