Home » Modeling » EMF » [CDO 4.1]Security Manager Problem(SecurityManager.getUser(UserId) timeout)
icon9.gif  [CDO 4.1]Security Manager Problem [message #889443] Tue, 19 June 2012 04:35 Go to next message
Xingxiao Lu is currently offline Xingxiao Lu
Member
Hi, Eike
Permission manager and security model is very good feature of CDO4.1. When I try it, I get Timeout Exception. User ID is 'Administrator', Password is '0000'.
[ERROR] Token encryption failed
org.eclipse.emf.cdo.common.util.TransportException: java.util.concurrent.TimeoutException
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:504)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:529)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.loadRevisions(CDOClientProtocol.java:166)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:382)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:293)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:276)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:269)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.getRevision(CDOViewImpl.java:697)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:839)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:748)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1093)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1065)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:676)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:644)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.get(CDOStoreImpl.java:190)
at org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateGet(EStoreEObjectImpl.java:241)
at org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEList.java:230)
at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:703)
at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
at org.eclipse.emf.cdo.security.RealmUtil.findUser(RealmUtil.java:31)
at org.eclipse.emf.cdo.server.internal.security.SecurityManager.getUser(SecurityManager.java:164)
at org.eclipse.emf.cdo.server.internal.security.SecurityManager$UserManager.encrypt(SecurityManager.java:489)
at org.eclipse.emf.cdo.internal.server.SessionManager.encryptToken(SessionManager.java:500)
at org.eclipse.emf.cdo.internal.server.SessionManager.authenticateUser(SessionManager.java:464)
at org.eclipse.emf.cdo.internal.server.SessionManager.openSession(SessionManager.java:232)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.OpenSessionIndication.responding(OpenSessionIndication.java:117)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:170)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:92)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)Thread-7 [debug.buffer] Obtained Buffer@55[INITIAL]
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:257)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:440)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:496)
... 36 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:204)
at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
at java.io.DataInputStream.readBoolean(DataInputStream.java:225)
at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readBoolean(ExtendedDataInput.java:60)
at org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:401)
at org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:396)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readRevision(RevisionInfo.java:218)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:157)
at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:143)
at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:1)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:90)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
... 40 more
[ERROR] Access denied
java.lang.SecurityException: Access denied
at org.eclipse.emf.cdo.internal.server.SessionManager.authenticateUser(SessionManager.java:471)
Re: [CDO 4.1]Security Manager Problem [message #889871 is a reply to message #889443] Wed, 20 June 2012 01:48 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 19.06.2012 10:35, schrieb Xingxiao Lu:
> Hi, Eike
Please note that this feature is not fully completed, yet. I wanted toget the needed APIs in so that I can fix the
remaining problems in 4.1 maintenance. The respective bugzilla is still ASSIGNED:
380629: Design a default Security model
https://bugs.eclipse.org/bugs/show_bug.cgi?id=380629
These default credentials are correct. I can't see the causal relation between the "[ERROR] Token encryption failed"
message and the timeout(s). Is it possible that you zip up your workspace and make it available for download to me? You
can send me a private email with the download link if it's confidential. Please also provide me with detailed steps to
make it run.
Cheers
/Eike
http://www.esc-net.de
> at
> ... 36 more
> ... 40 more
> at
Re: [CDO 4.1]Security Manager Problem [message #889949 is a reply to message #889871] Wed, 20 June 2012 07:24 Go to previous messageGo to next message
Member
Hi, Eike
I use the HEAD of CDO GIT repository.
CDOServer: Add 'security' bundles to 'CDOServer' in Run Configuration. Config the securityManager entiry in 'cdo-server.xml'. <securityManager type="default" realmPath="/security"/>
CDOClient: I use 'CDOExplorer'.
Hope this information will give you help.
Thank you for your professional reply.Smile
Re: [CDO 4.1]Security Manager Problem [message #900426 is a reply to message #889949] Tue, 07 August 2012 00:59 Go to previous messageGo to next message
Eclipse User
Hi Eike,
i experienced this too. After some debugging i tracked it down to a
deadlock with the transaction in SecurityManager.modify():
synchronized (transaction)
operation.execute(realm);
try {
transaction.commit();
} catch (CommitException ex) {
throw WrappedException.wrap(ex);
In the commit() call, the attached write acces handler is invoked which
tries to resolve the session user via getUser(). If the user is unknown,
the transaction is used to retrieve it from the realm. As this runs in a
separate thread it is blocked by the locked transaction.
When the synchronized block is removed, the deadlock is gone, but you
may experience other problems.
Greetings Joerg.
On 06/20/2012 01:24 PM, Xingxiao Lu wrote:
> Hi, Eike
> Thank you for your professional reply.:)
Re: [CDO 4.1]Security Manager Problem [message #900498 is a reply to message #900426] Tue, 07 August 2012 05:58 Go to previous messageGo to next message
Hi Jörg,
Thanks for taking the time to track this down! I'm currently extending the test bed so that we can more easily inject a
security manager from single test cases. I may come back with questions once that's done...
Cheers
/Eike
Am 07.08.2012 06:59, schrieb Joerg Pacher:
> Hi Eike,
> i experienced this too. After some debugging i tracked it down to a deadlock with the transaction in
> try {
> In the commit() call, the attached write acces handler is invoked which tries to resolve the session user via
> getUser(). If the user is unknown, the transaction is used to retrieve it from the realm. As this runs in a separate
> When the synchronized block is removed, the deadlock is gone, but you may experience other problems.
> Greetings Joerg.
>> Hi, Eike
Re: [CDO 4.1]Security Manager Problem [message #900677 is a reply to message #900426] Wed, 08 August 2012 03:08 Go to previous message
> Hi Eike,
> try {
I've solved this by opening a new transaction in ISecurityManager.modify().
I've also added lots of convenience methods to Realm, Directory and ISecurityManager.
And there's an easy test now, which you can use as an example in the future to demo remaining issues:
public class SecurityManagerTest extends AbstractCDOTest
private static final String USER_ID = "Stepper";
private static final String PASSWORD = "12345";
public void testCommit() throws Exception
ISecurityManager securityManager = startRepository();
securityManager.modify(new ISecurityManager.RealmOperation()
public void execute(Realm realm)
User user = realm.addUser(USER_ID, PASSWORD);
user.getGroups().add(realm.getGroup("Users"));
user.getRoles().add(realm.getRole("All Objects Writer"));
CDOSession session = openSession();
CDOTransaction transaction = session.openTransaction();
CDOResource resource = transaction.createResource(getResourcePath("/res"));
resource.getContents().add(getModel1Factory().createProduct1());
private ISecurityManager startRepository()
ISecurityManager securityManager = SecurityManagerUtil.createSecurityManager("/security", getServerContainer());
getTestProperties().put(RepositoryConfig.PROP_TEST_SECURITY_MANAGER, securityManager);
IPasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider(USER_ID, PASSWORD);
getTestProperties().put(SessionConfig.PROP_TEST_CREDENTIALS_PROVIDER, credentialsProvider);
getRepository(); // Start repository
return securityManager;
Cheers
/Eike
> Greetings Joerg.
>> Hi, Eike
Previous Topic:Slim Model Instance Backup
Next Topic:[CDO/Hibernate] Defining not-nullable EReferences
Current Time: Tue May 21 06:21:50 EDT 2013
Powered by FUDForum. Page generated in 0.01952 seconds
