| Decision can match input such as "'(' RULE_ID '=' RULE_INT ')'" using multiple alternative [message #900049] |
Fri, 03 August 2012 12:20  |
Laigle jérôme Messages: 26 Registered: August 2012 |
Junior Member |
I'm working on a DSL and i have a problem on declaration element
i want to support for example:
dcl a=3
dcl b=7
a=9
proc(a=3,b=7)
3 and 7 is the type of variable but 9 is an assignment
So, I've started with the following construct
Procedure:
'proc' name=ID (',d')? ('('argument+=VariableNameAndType (',' argument+=VariableNameAndType)* ')')? ((':' return+=VariableNameAndType)*)?
instructions+=Instruction* ;
Instruction:
VariableDeclaration|Expression;
Expression :
CompareOperator;
CompareOperator returns Expression:
PrimaryExpression(( {Inclusion.left=current} '='|{Equality.left=current}'=='|{NoInclusion.left=current}'!=') right=PrimaryExpression)*;
PrimaryExpression returns Expression:
NumericLiteral
| VariableOperande
| '(' Expression ')'
NumericLiteral:
value=Value;
Value:
NUMBER|INT
VariableOperande:
variable=[VariableName]
VariableDeclaration:
'dcl' variable=VariableNameAndType;
VariableName:name=ID;
VariableNameAndType:
name=VariableName type=Type;
Type:
BCDType
BCDType:
{BCDType}('='size=INT)?;
terminal INT returns ecore::EInt: ('0'..'9')*;
terminal NUMBER returns ecore::EBigDecimal:
('0'..'9')* ('.' ('0'..'9')+)?;
terminal ID : '<'?'^'?'"'? ('a'..'z'|'A'..'Z'|'$'|'_') ('a'..'z'|'A'..'Z'|'$'|'_'|'0'..'9')*'"'?'>'?;
But that's not working and I doubt that this is the right way. I'm new to Xtext and so this question might be quite stupid. Maybe somebody has an idea or can point me into the right direction? Thanks in advance!
Jérôme
| Re: Decision can match input such as "'(' RULE_ID '=' RULE_INT ')'" using multiple [message #900095 is a reply to message #900049] |
Fri, 03 August 2012 18:03   |
Henrik Lindberg Messages: 2426 Registered: July 2009 |
For starters, your INT and NUMBER terminals looks odd.
I think I get what you are trying to do here, but don' think that will
work. Ans since an INT was involved in the error message you got, I
think you need to address the terminals first.
Suggest writing a very small grammar with just your terminals, and some
very simple rules for parsing a sequence of INT and NUMBER, see if it
works ok.
This is what I used at one point:
terminal INT : ('0'..'9')+;
REAL hidden(): INT '.' (EXT_INT | INT);
terminal EXT_INT: INT ('e'|'E')('-'|'+') INT;
Note that REAL is *not* a terminal. If you don't need to support
scientific notation, simply do:
REAL hidden(): INT '.' INT;
Other potential problems are keywords like ",d" - use ',' 'd' instead,
and if you do not allow whitspace do something like:
Procedure:
'proc' name=ID CommaD? ......
CommaD hidden():
',' 'd'
Where you have a problem if you need to know if there was a CommaD or
not. So you may want to do:
Procedure:
'proc' name=ID commaD ?= CommaD? ......
Your variable references also look odd. You probably want to have
variable reference the variable declarations itself, not the name of it.
i.e use:
'dcl' name = ID type = Type
VariableOperand:
variable = [VariableDeclaration]
Hope that helps, but there may be other things going on, as this does
not seem to be the entire grammar.
- henrik
On 2012-03-08 18:21, Laigle jérôme wrote:
> dcl a=3
> dcl b=7
> a=9
> proc(a=3,b=7)
> Procedure:
> return+=VariableNameAndType)*)? instructions+=Instruction* ;
> Instruction:
> Expression :
> CompareOperator;
> NumericLiteral | VariableOperande
> | '(' Expression ')' ;
> NumericLiteral: value=Value; Value:
> NUMBER|INT
> ; VariableOperande:
> Type:
> BCDType
> BCDType:
> Best regards,
> Jérôme
FUDForum. Page generated in 0.01782 seconds
