Home » Eclipse Projects » Web Tools Project (WTP) » Get TreeSelection path
Get TreeSelection path [message #900102] Fri, 03 August 2012 21:50
rohit chawla is currently offline rohit chawla
Hi, What is a good way to get the location of current selection in packageExplorer? The selection instance returned is always TreeSelection. But how to get path from the TreeSelection. I am using the following ugly way, which sometimes work & sometimes does not?
I researched a lot on net, but didn't find any good solution.
		IPath path = null;
		try{
			Object element = ((TreeSelection) selection). getFirstElement();
			if (element instanceof JavaProject) {
				path = ((JavaProject) element).getPath();
			} else if (element instanceof PackageFragmentRoot) {
				path = ((PackageFragmentRoot) element).getPath();
			} else if (element instanceof PackageFragment) {
				path = ((PackageFragment) element).getPath();
			return path.toString();
Previous Topic:entity expansion limit
Next Topic:Creating JSP, XML got fatal errors please help :(
Current Time: Sun May 19 00:29:50 EDT 2013
Powered by FUDForum. Page generated in 0.01980 seconds
