Home » Modeling » MoDisco » Discovering multiple related java projects
Discovering multiple related java projects [message #899848] Thu, 02 August 2012 11:01 Go to next message
Benjamin Klatt is currently offline Benjamin Klatt
Member
We are analyzing software which is developed within multiple java projects.
However, selecting all required plugins and choosing to discover them
  • starts the java and inventory model discoverer once per project
  • requires us to put in the discoverer options once per project and
  • generates multiple java2kdm file sets which are not interconnected
Is there any way to discover multiple java projects at once to ensure all dependencies between model/java elements are resolved?
Benjamin
Re: Discovering multiple related java projects [message #900036 is a reply to message #899848] Fri, 03 August 2012 10:52 Go to previous messageGo to next message
Fabien Giquel is currently offline Fabien Giquel
Hi Benjamin,
yes there is a dedicated way to do it, unfortunetaly it seems there is some issue with it :
when you select one of your java project (which have dependencies to other of your projects), on "java and inventory model discoverer" parameters screen, you may click on "ELEMENTS_TO_ANALYZE" button and select not only one but several projects among dependencies to reverse to one single jav2kdm model.
After some basic tests, i observe some "IllegalArgumentException: No Null constraint". This multi-project selection works fine with simple java model discoverer. I think there is some issue in kdm model mapping with directories in several workspace projects.
I will feed some bugzilla about it.
Fabien.
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
Re: Discovering multiple related java projects [message #900038 is a reply to message #900036] Fri, 03 August 2012 10:59 Go to previous messageGo to next message
I entered the bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=386579
Fabien GIQUEL
R&D Engineer
Mia-Software
Re: Discovering multiple related java projects [message #900555 is a reply to message #900038] Tue, 07 August 2012 09:55 Go to previous messageGo to next message
Member
Thanks for pointing to this function. I could reproduce the bug you described above.
I added myself to the cc list of the bug to get notified.
Re: Discovering multiple related java projects [message #900556 is a reply to message #899848] Tue, 07 August 2012 09:56 Go to previous message
Member
Previous Topic:PHP discoverer
Next Topic:Loading java2kdm Models - Best Practices?
Current Time: Fri May 24 11:37:30 EDT 2013
Powered by FUDForum. Page generated in 0.01775 seconds
