Home » Modeling » QVT-OML » Best practice to check OCL invariants from inside QVTo script
Best practice to check OCL invariants from inside QVTo script [message #899794] Thu, 02 August 2012 07:34 Go to next message
Christopher Gerking is currently offline Christopher Gerking
Member
Several OCL invariants are specified as part of my meta-model. During generation of an instance of this meta-model, I have to check conformance with all specified invariants from inside the QVTo script. The check must happen during the transformation, since further results depend on it.
I see different possibilities to achieve this:
1. Move all invariants to operations/attributes. Call the operation or attribute inside the invariant and also from my QVTo script.
2. Create a blackbox library and introduce an evaluation operation, which uses existing validation code.
3. Make invariants 'callable'. Is there an example available? Inserting the keyword to my ecore file recently crashed it...
Using the blackbox library brings the advantage of not invoking all the invariants individually. Is this the solution to go for?
Re: Best practice to check OCL invariants from inside QVTo script [message #899815 is a reply to message #899794] Thu, 02 August 2012 08:39 Go to previous message
I would do both.
Use the blackbox for development for which Java debugging will be helpful.
Raise a Bugzilla on your bad callable example please.
Ed Willink
> depend on it.
Previous Topic:Code style / Performance / Best practice question
Next Topic:Modifying QVT Traceability.
Current Time: Sat May 25 07:22:25 EDT 2013
Powered by FUDForum. Page generated in 0.03070 seconds
